    Auto Find and Replace 6 Keywords in a Script between to different pages
    15 Posts 5 Posters 6.2k Views 3 Watching
    • WilderloreW Offline
      Wilderlore
      I have a script that is complete and runs fine, but I have to manually change 6 keywords at the end of lines like so:
      'ITEM A
      TAG POS=1 xxxxxxxxxxxxxxxxxxxxxx
      TAG POS=1 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_NAME
      TAG POS=1 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_START_DATE
      TAG POS=1 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_END_DATE
      TAG POS=1 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_TIME
      TAG POS=3 xxxxxxxxxxxxxxxxxxxxxx
      TAG POS=3 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_ID
      TAG POS=2 xxxxxxxxxxxxxxxxxxxxxx ITEM_1_NEW
      I have to manually do this for 10 or more different ITEMS
      My question is if there is a easy way where I can have a setup on another page that only has the 6 keywords I need to change and have it automatically be inputted in original script? Along the lines of:
      'ITEM A
      =ITEM_1_NAME
      =ITEM_1_START_DATE
      =ITEM_1_END_DATE
      =ITEM_1_TIME
      =ITEM_1_ID
      =ITEM_1_NEW
      'ITEM B
      =ITEM_2_NAME
      =ITEM_2_START_DATE
      =ITEM_2_END_DATE
      =ITEM_2_TIME
      =ITEM_2_ID
      =ITEM_2_NEW
      And so on to ITEM J or the 10th Item.
      The Template itself doesn’t change other than those words, but I tend to mess up now and then due to the fact that all the items will have different DATES and TIMES. So I was hoping to have a user friendly plug and play template that will auto find and replace every instance of those words in the Page that contains the full script template without messing up the script itself.
      Neil SchipperN PeterJonesP 2 Replies Last reply Reply Quote 0
      • Neil SchipperN Offline
        Neil Schipper @Wilderlore
        @Wilderlore If you’re still around and hoping for a reply, say so and I’ll describe the things about your problem description that are confusing and ambiguous and require the reader to make guesses. Even better, re-read your problem description critically – you’ll be reading with fresher eyes than when you composed it – and make another attempt.
        WilderloreW 1 Reply Last reply Reply Quote 1
          PeterJones @Wilderlore
          @Wilderlore ,
          We’re having trouble understanding what you want. You will have to be more clear.
          My guess is that you want “mail merge” capabilities: Notepad++ doesn’t have that feature, nor are there any plugins that do it that I know of. I talked about that a little over here, including pointing out a plugin that makes multiline S&R a little easier… though I don’t know if it will be sufficient for your needs, since I cannot understand for sure what your needs are.
            Wilderlore @Neil Schipper
            @Neil-Schipper yep I’m still around and would appreciate any help.
            I’ve looked over with “fresh eyes” and I do see how it could be hard to understand, but because is sensitive information, I had to replace the sections of the script that never changes with those “xxxxxxxx”
            But like I said, the script does work as is, but I would like to expedite the process of changing those items that change on the daily.
            • Alan KilbornA Online
              Alan Kilborn @Wilderlore
              @Wilderlore said in Auto Find and Replace 6 Keywords in a Script between to different pages:
              I don’t think the x’s have anything to do with why your problem is hard for others to understand…
              WilderloreW 1 Reply Last reply Reply Quote 0
                Unfortunately, you gave us no new information, so you did nothing to help us understand the changes you want to make. As a result, we still cannot help you.
                Useful References
                • Please Read Before Posting
                • Formatting Forum Posts
                • FAQ: Where to find regular expressions (regex) documentation
                  Wilderlore @Alan Kilborn
                  Would you mind telling me what is the source of confusion then?
                  My objective is to easily find and replace those 6 keywords while eliminating the potential human error of messing up the rest of the script. I am not too knowledgeable about this subject, so I apologize for not knowing where the confusion is.
                  If you are familiar with the camera add-on in excel, it basically duplicates the table on one tab and any chnage made on the original table will be replicated on the copy table on a 2nd tab. I’m looking for something similar in Notepad ++
                  • guy038G Offline
                    Hello @wilderlore, @neil-schipper, @peterjones and All,
                    I tried to guess what your goal is ! So, this is my first try :
                    From this INPUT file :
                    'ITEM A
                    'ITEM B
                    Do you expect the following OUTPUT text :
                    'ITEM A
                    =ITEM_1_NAME
                    =ITEM_1_START_DATE
                    =ITEM_1_END_DATE
                    =ITEM_1_TIME
                    =ITEM_1_ID
                    =ITEM_1_NEW
                    'ITEM B
                    =ITEM_1_NAME
                    =ITEM_1_START_DATE
                    =ITEM_1_END_DATE
                    =ITEM_1_TIME
                    =ITEM_1_ID
                    =ITEM_1_NEW
                    In this case, it’s easy with regular expressions ! Here is a possible solution :
                    • Open your file in Notepad++
                    • SEARCH (?-si)(?|^TAG POS.+?( ITEM_.+)?(?:\R|\z)|^('ITEM \u))
                    • REPLACE ?1=\1\r\n    or    ?1\1\n if you work with UNIX files
                    • Untick all box options
                    • Tick the Wrap around option
                    • Click once on the Replace All button
                    Here you are : your text is now changed as below :
                    'ITEM A
                    = ITEM_1_NAME
                    = ITEM_1_START_DATE
                    = ITEM_1_END_DATE
                    = ITEM_1_TIME
                    = ITEM_1_ID
                    = ITEM_1_NEW
                    'ITEM B
                    = ITEM_1_NAME
                    = ITEM_1_START_DATE
                    = ITEM_1_END_DATE
                    = ITEM_1_TIME
                    = ITEM_1_ID
                    = ITEM_1_NEW
                    WilderloreW Neil SchipperN 2 Replies Last reply Reply Quote 0
                      @Wilderlore ,
                      Notepad++, except during printing, has no concept of “on a different page”.
                      If by “page” you mean “in a separate text file”, Notepad++ has no native way of reading the contents of one file, and using those contents to affect changes in another file. There are scripting solutions, if you have a scripting plugin, but I have no idea whether to suggest the one I’m thinking of to you or not, because you haven’t shown us enough to be able to really tell what you want.
                      For example, when Guy just tried to guess what you wanted, I think he got it exactly backwards from the direction that I thought you wanted the transformation. That means that you haven’t even successfully told us which direction you want the transformation to go.
                      That is why I linked you to some general-purpose and search-and-replace-specific information from the forum. If you at least gave us a good picture of the data “before” and “after” your transformation, we might have a chance. But if we cannot tell which is your “before” and which is your “after”, then there’s no hope that we can help you.
                        Wilderlore @guy038
                        @guy038
                        Thank you so much! I think that is what I’m looking for! I will give it go next time!
                        And sorry to everyone else for the confusion. I truly no nothing about coding, but I appreciate everyone’s patience!
                          Neil Schipper @guy038
                          @guy038 Hi Guy, I enjoyed seeing the revert subexpression counter in each branch of an alternation construct ((?|) used in a real world problem, which is something I’ve never done, or even seen done as best as I can recall.
                          But then I studied the expression for a bit, and got to wondering why it was necessary to match (and write back) the header lines (that start 'ITEM..). Anyway, I ran it, and was surprised to find that it does not produce exactly the stated desired output, and also doesn’t produce the sample output you provided, differing (very slightly) from both.
                          Here’s what is produced when I run it:
                          ='ITEM A
                          = ITEM_1_NAME
                          = ITEM_1_START_DATE
                          = ITEM_1_END_DATE
                          = ITEM_1_TIME
                          = ITEM_1_ID
                          = ITEM_1_NEW
                          ='ITEM B
                          = ITEM_1_NAME
                          = ITEM_1_START_DATE
                          = ITEM_1_END_DATE
                          = ITEM_1_TIME
                          = ITEM_1_ID
                          = ITEM_1_NEW
                          Again, the deviations are very slight: (1) a ‘=’ is placed before the header line, and (2) a space is added after ‘=’ in each body line. (As to whether these deviations impact whether the requirements of the original request are met, I have no Ouija board handy to determine that.)
                          To produce the stated desired output, this simpler expression can be used:
                          Fi: (?-si)^TAG POS.+?(\h(ITEM_.+))?(?:\R|\z)
                          Re: ?2=\2\r\n
                          In any event, thanks for giving me an excuse to shake out some cobwebs in my mind.
                          @PeterJones Hi. In regard to the documentation of the so-called branch reset directive (I like my wordier name for it as per above), there are some issues. Most important are the errors in:
                          Without the branch reset, (y) would be group 3, and (p(q)r) would be group 4 …
                          Both of those group numbers are off by one (corrections are in example below).
                          The other issues are minor: a stray forward slash in the line that includes the example expression / (?x) .., and, vertical misalignment of the helper comment line that shows the counts, and finally, a missed opportunity for helping a reader (like me) absorb the lesson (without having to read it 4 - 6 times).
                          Here’s my suggested replacement text for the example section:
                          For example, consider these two expressions that use alternations, the first one using normal branch counting (but uses (?: to skip one subexpression from being counted), and the second one using the branch-reset mechanism:
                          #    -------------------no branch-reset-----------------
                          (?x) ( a )  (?: x ( y ) z | (p (q) r) | (t) u (v) ) ( z )
                          #      1   skip     2        3  4        5     6      7  <=== assigned subexpression counter values
                          #              ---------branch-reset zone---------
                          (?x) ( a )  (?| x ( y ) z | (p (q) r) | (t) u (v) ) ( z )
                          #      1   skip     2        2  3        2     3      4  <=== assigned subexpression counter values
                          Two things to note about the latter case are:
                          1. the branch-reset bounding subexpression does not get a count for itself.
                          2. it’s possible that intermediate subexpressions won’t exist. In this case, the text axyzz matches using the first alternate, and subexpression 3 does not exist, and subexpression 4 does.
                          It’s a bit longer than the original but the mechanism is quite subtle so I hope you’ll see fit to update the manual.
                          • guy038G Offline
                            Hi @wilderlore, @neil-schipper, @peterjones and All,
                            @neil-schipper :
                            Oh yes , you’re perfectly right about it ! I just forgot this simple rule :
                            You never need, in your search regex, to involve lines which do not change between the INPUT and OUTPUT texts !
                            So, as I don’t have to take care about lines 'ITEM A, 'Item B …, the Branche Reset feature is useless and the regex can be simplified as you did :-))
                            In addition my version wrongly added an equal sign, at beginning of lines 'ITEM A, 'Item B …, as well as an extra line-break right after. My bad !
                            Now, regarding the N++ documentation, indeed, the lines :
                            #      before  ---------------branch-reset----------- after
                            / (?x) ( a )  (?| x ( y ) z | (p (q) r) | (t) u (v) ) ( z )
                            #      1            2         2  3        2     3     4
                            Without the branch reset, (y) would be group 3, and (p(q)r) would be group 4, and (t) would be group 5. With the branch reset, they both report as group 2
                            should be changed as :
                            #    before --------------branch-reset------------- after
                            #    1      x     2         2  3        2     3     4
                            whereas the classical syntax is :
                            #    -------------------no branch-reset------------------
                            #    1      x     2         3  4        5     6     7
                            Without the branch reset, (y) would be group 2, (p(q)r) would be group 3, (q) would be group 4, (t) would be group 5 and so on.... With the branch reset, groups (y), (p...) and (t) both report as group 2
                            Peter, don’t bother about the bold highlighting of some words, automatically created when you begin lines with 4 space chars !
                            Neil, you added :
                            2 it’s possible that intermediate subexpressions won’t exist. In this case, the text axyzz matches using the first alternate, and subexpression 3 does not exist, and subexpression 4 does
                            Nothing weird here ! As your axyzz string matches only the first alternative of the Branch Reset which does not involve the group 3 :
                            • The group 1, before the Branche Reset, is defined
                            • The group 2, within the first alternative of the Branche Reset, is defined
                            • The group 4, after the Branche Reset is defined
                            • The group 3, part of the other alternatives of the Branche Reset, is not defined
                              PeterJones @guy038
                              @guy038 , @neil-schipper,
                              I mentioned this to Neil in a private message, but should have posted it here for others, too: The PR#414 shows the changes I made. Do those look good to you?
                              FYI, you can convince the forum to not bold random words in code blocks.
                              Compare
                              without the branch reset, (y) would be group 2, ...
                              rendering as
                              to
                              ```txt
                              rendering as
                              If you use a known markdown-file-type after the opening ``` (or ~~~, if that’s your preferred character), then the forum doesn’t try to guess what programming language it is, instead using whatever you tell it. And telling it ```txt tells the forum to not do any formatting of the text.
                              (This is why Scott used to recommend ```z, because that also tells the Markdown it’s filetype “z”, which doesn’t exist, so the forum also doesn’t try to highlight it.)
                                @PeterJones said in Auto Find and Replace 6 Keywords in a Script between to different pages:
                                I picked up that habit as well, but a slight downside is you get no background differentiation with it:
                                hello world
                                This perhaps calls less attention to it…good thing or bad…I don’t know.
                                  @Alan-Kilborn said in Auto Find and Replace 6 Keywords in a Script between to different pages:
                                  Ah, right, I forgot that. So using the ```txt will keep it in the backgrounded box, whereas ```z will make it blend in more with normal text.
