    CASE statement help lines
    7 Posts 2 Posters 2.7k Views 2 Watching
    • rvw80R Offline
      rvw80
      left is np++ right another tool (TOAD)
      theres a nice help lines indicating the structure for my case statement;
      anyone know of anything in np++ that would get me something similar?
      thanks in advance for any word!
      Kr
      Ron
        PeterJones @rvw80
        @rvw80 ,
        You don’t tell us what language you are using; since there are more than 80 languages in Notepad++, that makes it hard to replicate your results, since you would be relying on the person who is helping you to just happen to recognize what language it is you are using. You also don’t give us any example text in a text box using the </> button in the post-creating window, so instead of being able to copy/paste your example text, we have to read a shrunken image and then type it ourselves. :-(
        That said, the folding and the indent guides together are supposed to indicate the current level for code blocks.
        If you look on the folding column from row 154 to 174 (the entirety of the active CASE region), the folding for that section is marked red, as the active fold. (That color is set by the Settings > Style Configurator > Global Styles > Fold active color setting)
        Normally the indent guides (the dotted vertical lines) also help with that, but since yours seem to be every character, rather than every Nth character, they seem less useful to me. Do you have your tab size set to 1 for the active language (Settings > Preferences > Language > <language name> > Tab size)? I guess that might make sense if you really don’t want a fixed column width (it looks like some of your columns are 5, some are 6, if I count invisible spacing correctly in your image), but that would annoy me to no end – why not set it to 5 or 6 characters and have consistent column alignment? Oh, well, to each their own.
        rvw80R 1 Reply Last reply Reply Quote 1
        • rvw80R Offline
          rvw80 @PeterJones
          @PeterJones hi Peter this is SQL
          rvw80R 1 Reply Last reply Reply Quote 0
          • rvw80R Offline
            rvw80 @rvw80
            this is a snippet of the SQL:
                       CASE
                       WHEN  -- any trx_class except CM
                             apsa.class <> 'CM'
                       THEN
                            CASE
                            WHEN -- due after as-of-date
                                 apsa.due_date > to_date(to_char(aod.asofdate,'YYYY/MM/DD'))
                            THEN
                                 CASE
                                 WHEN      'Local Currency' = 'Local Currency'
                                       AND apsa.exchange_rate_type IS NOT NULL
                                 THEN
                                       ar_arxagmw_xmlp_pkg.due_amt_as_of_date(aod.asofdate
        ,apsa.amount_due_remaining
        ,apsa.payment_schedule_id
        ,apsa.class)
                                       * apsa.exchange_rate
                                 ELSE
        ,apsa.class)
                                 END
                            ELSE -98
                            END
                       ELSE  -- apsa.class = 'CM'
                            CASE
                            WHEN trunc(apsa.gl_date_closed) <= trunc(to_date(to_char(aod.asofdate,'YYYY/MM/DD')))
                            THEN
                                 -99
                            ELSE
                                 CASE
                                 THEN
        ,apsa.class)
                                 ELSE
        ,apsa.class)
                                 END
                            END
                       END
            • rvw80R Offline
              rvw80 @rvw80
              i saw putting CASE between brackets gives this
              would be nice it could give the bracket vertical lining on the CASE itself allready
                PeterJones @rvw80
                @rvw80 ,
                As I said, Notepad++'s solution for showing you what level of code-folding you are at is to color the folding indicators on the left, which all your screenshots have shown is working right.
                The red you showed in your most recent screenshot is the parentheses-matching feature of Notepad++, which is independent of language and a completely separate feature from the block/folding indicator already described. (It works even when no language is selected – ie, on plain text, which has no concept of blocks/folding.)
                And as this Forum’s various FAQs, including the “Please Read Before Posting”, we fellow users in the Forum cannot make changes to the codebase for you. We can only help you with features that are already there, and sometimes make suggestions for workarounds. Even if you do follow the FAQs to figure out where to make a feature request, it is my guess that the developers would not implement anything new, because Notepad++ already shows you which level of block/folding you are at.
                • rvw80R Offline
                  rvw80 @PeterJones
                  now i see what you mean with that
                  hadnt noticed that! that helps
                  thanks for you replies!
