    Notepad++ Randomly Reset and I lost a project
    6 Posts 3 Posters 991 Views
    • himno2222H
      himno2222
      Hey everyone!
      Hoping to find some answers here
      Last night I shut down my computer, everything was well
      Today I woke up with Notepad++ totally resetting the settings I set for it (the color theme, the size of the text etc) and unfortunately it also randomly deleted all the content inside one of the notepad documents that I had written
      Why is this happening / how can I recover the document? It was very important
      Thank you
        Terry R @himno2222
        @himno2222 said in Notepad++ Randomly Reset and I lost a project:
        You have given us very little information. But in spite of that we will try to help. In the first instance read the FAQ post titled “Periodic Backup vs AutoSave Plugin”.
        Then you will need to provide information such as Windows and Notepad++ versions. Again there are FAQ posts expending on this. Also you say you shut down the PC, did you close Notepad++ first?
        himno2222H 1 Reply Last reply Reply Quote 2
        • himno2222H
          himno2222 @Terry R
          @Terry-R Sorry for the lack of info. I was a bit stressed out and annoyed when I left this -
          I saved it for sure, and I’m about 90% sure I also closed it
          I use Windows 10 Pro, and the Notepad++ version is 8.1.2 32bit.
          I think it might have something to do with the fact that I had 0 space left in Local Disk C? (I installed an app and it took up all the space)
          Can I do anything about it?
          Terry RT Alan KilbornA 2 Replies Last reply Reply Quote 0
            Terry R @himno2222
            Well, that is a death wish! If that’s true there is probably very little likelihood of retrieving anything.
            If you read the FAQ post I referred to previously you will have read that in the event of the file having been deleted there is sometimes a chance of “restoring” it. But in order to do so, there needs to be free space (and generally lots of it).
            You see, Windows will delete a file, but it doesn’t actually clear out the space, just tags it as being free. If there is heaps of free space, the system (and other apps) will use the free space, but will likely not overwrite the area the deleted file used for a period of time. That’s the chance you have of recovering it. The smaller the free space available, the less time before your deleted file is overwritten.
            With 0 (zero) free space I think your chance of recovering the file (if deleted) is also 0.
            You can try to search your PC for the file if it hasn’t been deleted. Normally I’d say install an app that can search the contents of all files for a known string that your file contains, but with 0 free space that’s not possible.
            It may not help much now, but going forward you will need to maintain a better system, with free space and also make sure the backup system within Notepad++ is set to how you want it, again read that FAQ post.
            Good luck
            himno2222H 1 Reply Last reply Reply Quote 1
              Alan Kilborn @himno2222
              Well, there are a couple of Notepad++ issues on just that circumstance, see #5664 and #11822 for maybe some relevant reading.
              • himno2222H
                himno2222 @Terry R
                @Terry-R All right. Thank you for being so kind and answering.
                Have an amazing day!
