    Strange behavior of the sort function, with zero-length column mode selection
    18 Posts 4 Posters 4.0k Views 1 Watching
    • guy038G Offline
      Hi, All,
      I would like to get your feedback on this weird behavior. Could you confirm me that there is a problem ?
      IMPORTANT : Although, I installed the BetterMultiSelection plugin, on my local N++ v8.4.6 configuration, I disabled this plugin during the tests !
      Follow exactly all the subsequent steps :
      • In a new tab, insert the text, below :
          xyz
          -PQR
          AB-C
          abc
          ABCDEF
          abcdef
          ABC-DEF
          -pqr
          ab-c
          x-yz
          X-YZ
          ABC
          abc-def
          XYZ
      Just note that these lines are randomly sorted.
      • Now, make a zero-length column-mode selection of all the lines, right after the four space chars ( indication Sel: 14x0 in the status bar )
      • Type in, for instance, a double-quote " ( to be sure that you’ve entered in the column-mode ! )
      • Run the option Edit > Line Operations > Sort Lines Lexicographically Ascending
      => No modification occur !?
      • Hit the Del key to delete all the "
      • Run, again, the Edit > Line Operations > Sort Lines Lexicographically Ascending option
      => Still, no change occur !?
      • Hit the Left Arrow key to cancel the colum mode
      • Again, make a zero-length column-mode selection of all the lines, right after the four space chars ( indication Sel: 14x0 in the status bar )
      • Select, for the last time, the Edit > Line Operations > Sort Lines Lexicographically Ascending option
      => This time, as expected, the lines are correctly sorted ( Lexicographically Ascending ), as below :
          -PQR
          -pqr
          AB-C
          ABC
          ABC-DEF
          ABCDEF
          X-YZ
          XYZ
          ab-c
          abc
          abc-def
          abcdef
          x-yz
          xyz
      Notes :
      • If, instead of the leading space chars, you insert a tabulation char, for all the lines and repeat the same steps, the problem persists :-(
      • If the BetterMultiSelection is enabled, the problem is identical, too !
      Let’s try an other test :
      • Insert the example test in a new tab
          xyz
          -PQR
          AB-C
          abc
          ABCDEF
          abcdef
          ABC-DEF
          -pqr
          ab-c
          x-yz
          X-YZ
          ABC
          abc-def
          XYZ
      • Make a zero-length column-mode selection of all the lines, right after the four space chars ( indication Sel: 14x0 in the status bar )
      • Type in, for instance, the sharp char # ( to be sure that you’ve entered in the column-mode ! )
      • Run the Edit > Line Operations > Sort Lines Lexicographically Ascending option
      => As said above, no modification occur !?
      • Now, hit simultaneously the Alt and Shift keys and successively the Right Arrow and Left Arrow keys
      => This time, although the resulting column mode is STILL a zero-length selection, the behaviour of the sort is correct and gives, as epected :
          -PQR
          -pqr
          AB-C
          ABC
          ABC-DEF
          ABCDEF
          X-YZ
          XYZ
          ab-c
          abc
          abc-def
          abcdef
          x-yz
          xyz
      In summary, sort does not seem to occur when, simultaneously :
      • A column-mode selection is active
      • A char have been added or deleted
      • The column-mode selection is a zero-length one
      On the contrary, the sort seems correct if :
      A non-zero length column-mode selection is active
      OR
      A resulting zero-legnth column-mode selection is active
      OR
      No modification of the column-mode selection have been occurred
      P.S. :
      Notepad++ v8.4.6   (64-bit)
      Build time : Sep 25 2022 - 19:51:39
      Path : E:\846_x64_RC3\notepad++.exe
      Command Line :
      Local Conf mode : ON
      OS Version : 21H2
      OS Build : 19044.2075
      Plugins :
          mimeTools (2.8)
          NppConverter (4.4)
          ComparePlus (1)
          BetterMultiSelection (1.5)
        @guy038
        If you make a column selection, then the Scintilla function SCI_SELECTIONISRECTANGLE will return 1 meaning true.
        However, if after making the column selection, you use it to modify text, a call to SCI_SELECTIONISRECTANGLE will then return 0 meaning false, even though you can plainly see with your eyes that your column selection is still reasonable and valid. Apparently the column selection is now considered “n” separate selections (multi-select), where “n” is the number of lines covered by the selection. And…subsequent actions that depend upon column mode will possibly act strangely, as you’ve discovered.
        You can try checking the Scintilla mode yourself by going to the PythonScript console window and typing editor.selectionIsRectangle() at the >>> prompt and pressing Enter, after you’ve set up your desired conditions in the editing window. This will show you what Scintilla thinks the current state is. Of course, you’d have to add PythonScript to your plugins for this.
        Note that from the PS console window, to get back to the editing window without altering your previously made selection, you might want to use the “two taps on the Windows key” trick, to experiment further. Clicking with the mouse into the editor window will destroy your previously set up selection.
        • PeterJonesP Online
          PeterJones @guy038
          @guy038 ,
          Alan reminded me in chat about the conversation PythonScript Toggleable Script?, where I developed SelectionToRectangle.py, which converted a normal stream selection to a column (rectangle) selection.
          Using the concepts from that, I saw that after your manipulation (above) the selection converts from a rectangle selection to a multi-selection. If I just ran the SelectionToRectangle.py, the modes claim to be a rectangular selection again… but looking at the selection start/end, it’s a one-row rectangle, so not very columnar.
          However, before doing the conversion, the multi-selection still had the original extents for the beginning and end of selection. So using those values to create a new stream selection, and then using the SelectionToRectangle to convert to rectangular from that new stream, I think it works as desired:
              one
              two
              three
              four
          Instructions:
          1. Save this script, and optionally assign it a keyboard shortcut
          2. use the one…four text above, do a column selection between the fourth space and the letters
          3. type " then backspace to replicate Guy’s issue
          4. Edit > Line Operations > Sort Lines Lexicographically Ascending – order should still be one, two, three, four, because it doesn’t sort because of multi-selection
          5. run this script
          6. Edit > Line Operations > Sort Lines Lexicographically Ascending – order should now be four, one, three, two, because it went back to column/rectangle-selection
          # encoding=utf-8
          Derived from SelectionToRectangle.py from 22890-simplest.py, in response to https://community.notepad-plus-plus.org/topic/23564,
          which had (accidentally) changed a Column Selection to a Multi-Selection instead. This converts a multi-selection to a column-selection
          from Npp import notepad, editor, SELECTIONMODE, STATUSBARSECTION
          #console.clear()
          #console.write("PRE:  {}..{} R:{} M:{}\n".format(editor.getSelectionStart(), editor.getSelectionEnd(), editor.selectionIsRectangle(), editor.getMultipleSelection()))
          if not(editor.selectionIsRectangle()) and (editor.getMultipleSelection()):
              ss,se = editor.getSelectionStart(), editor.getSelectionEnd()
              #console.write("GET:  {}..{} R:{} M:{}\n".format(editor.getSelectionStart(), editor.getSelectionEnd(), editor.selectionIsRectangle(), editor.getMultipleSelection()))
              editor.setSelection(ss,se)
              #console.write("SET:  {}..{} R:{} M:{}\n".format(editor.getSelectionStart(), editor.getSelectionEnd(), editor.selectionIsRectangle(), editor.getMultipleSelection()))
              editor.setSelectionMode( SELECTIONMODE.RECTANGLE )
              #console.write("RECT: {}..{} R:{} M:{}\n".format(editor.getSelectionStart(), editor.getSelectionEnd(), editor.selectionIsRectangle(), editor.getMultipleSelection()))
          notepad.activateFile(notepad.getCurrentFilename()) # use the activateFile() command to refresh UI; otherwise, it doesn't _look_ like column/rectangle select)
          #console.write("POST: {}..{} R:{} M:{}\n".format(editor.getSelectionStart(), editor.getSelectionEnd(), editor.selectionIsRectangle(), editor.getMultipleSelection()))
            Some more research and experimentation:
            The reason it changed mode out of Rectangle mode is because Scintilla has a selection mode called SC_SEL_THIN which indicates “the mode after a rectangular selection has been typed into and ensures that no characters are selected”. So what Guy found is not a bug: rather, Scintilla intentionally leaves pure Rectangle Selection Mode (SC_SEL_RECTANGLE) after you make edits; and the line operation sorting functions only work with stream or rectangle selections, not with “thin” selections or multi-selections.
            The script I showed above will get you back into full rectangle mode from the THIN mode, but not from any others.
            I have now updated my original SelectionToRectangle.py to work whether the active selection is starting from a normal (“stream”) selection, from an edited-column (“thin”) selection, or from a multi-selection: all three of those will be converted into a column-mode selection. And if it’s already a column-mode (“rectangle”), it will remain unchanged.
            SelectionToRectangle.py v2022.10.06
            # encoding=utf-8
            Derived from 22890-simplest.py, in response to https://community.notepad-plus-plus.org/topic/22890/
            2022-Oct-06: modify based on https://community.notepad-plus-plus.org/topic/23564 to convert either stream selection (old behavior) or multi-selection (new behavior) to a single column selection
            This is the simplest paradigm for converting a stream (normal) selection to rectangular (column):
            1) Click or arrow to where you want to start selecting
            2) Shift+Click or Shift+arrow to get to the end of the selection (ie, do a normal selection)
            3) Run this script to convert the selection from STREAM to rectangle and refresh the screen automatically to see it
            You can also start with a Multi-Selection (multiple Ctrl+Clicks) and convert it, with the start of the column at the lowest selection-start, and the end of the selection at the highest selection-end
            if editor.getSelectionMode()==SELECTIONMODE.THIN:    # this is the mode after making an edit in rectangle(column) mode
            if editor.getSelectionMode()==SELECTIONMODE.STREAM and editor.getSelections()>1:    # this is multi-selection mode
                ss = None
                se = None
                for si in range(0, editor.getSelections()):
                    s0 = editor.getSelectionNStart(si)
                    s1 = editor.getSelectionNEnd(si)
                    if ss is None or s0 < ss: ss = s0
                    if se is None or s1 > se: se = s1
            if editor.getSelectionMode()!=SELECTIONMODE.RECTANGLE:
            2024-Oct-16 Fix: instead of using <> for “not equal”, use != (see 2024-Oct-14 post below for reasons)
            Alan KilbornA 2 Replies Last reply Reply Quote 3
              @PeterJones said in Strange behavior of the sort function, with zero-length column mode selection:
              So what Guy found is not a bug…the line operation sorting functions only work with stream or rectangle selections, not with “thin” selections.
              To me it sounds like Guy found a Notepad++ bug. When sorting, a zero-width selection – declared by code as “thin” or not, user doesn’t care about that distinction in this circumstance – over a number of lines is supposed to use as the sort key the data starting in the column of the selection and continuing to end-of-line (for each line). Note that this is a bit different from a sort using a non-zero width column selection, where the sort key is only the text shown as selected on each line.
                @Alan-Kilborn said in Strange behavior of the sort function, with zero-length column mode selection:
                To me it sounds like Guy found a Notepad++ bug. …
                From that perspective, it does sound like it doesn’t meet user expectations.
                So yeah, Guy should go ahead and report it as a bug. If he does, it would be best to explain that SC_SEL_RECTANGLE sorts as expected, but SC_SEL_THIN does not sort when it is expected to do so.
                  I’d think changing THIS from:
                  if (_pEditView->execute(SCI_SELECTIONISRECTANGLE))
                  to:
                  if ((_pEditView->execute(SCI_SELECTIONISRECTANGLE)) || (_pEditView->execute(SCI_GETSELECTIONMODE) == SC_SEL_THIN))
                  should fix it.
                  • guy038G Offline
                    Hello, @alan-kilborn, @peterjones and All,
                    Many thanks for your feedback ! I now understand the problem and, certainly, the last suggestion of Alan seems the correct one !
                    I’ll create a new issue, very soon ! We’ll just have to live what this tiny problem !
                    Of course, we could, as well, have simply used the Stream Selection, right before the sort. In this case, the result is always correct !
                    Now, Peter and Alan, I’m upset by a behavior, a bit off-topic, relative to the PythonScript plugin. Let me explain :
                    On my new Windows 10 laptop, I still did not transfer all my personal data from my old XP laptop. So, in the meanwhile, I use an USB key ( E: ), containing some folders whose one is 846_x64_RC3 which contains the last locale N++ version
                    After installing, as you suggested, the PythonScript plugin with the Plugins > Plugin Admin... option, I selected the Plugins > PythonScript > New Script option which created an empty Test.py file in the folder E:\846_x64_RC3\plugins\Config\PythonScript\Scripts. Then, I pasted the contents of the @pterjones script, below, and re-saved it :
                    # encoding=utf-8
                    #console.clear()
                    The INPUT text was in E:\xxx.txt file and, after following the @peterjones instructions, everything was OK !
                    However, I do not understand why IF I select again the Plugins > PythonScript > New Script option, this time, the Save under... windows proposes to save the future .py file in the \E folder instead of the normal location E:\846_x64_RC3\plugins\Config\PythonScript\Scripts ?!
                    Do you have some hints about it ? I surely miss something obvious !
                    Thanks, in advance !
                    Command Line :
                    OS Version : 21H2
                    Plugins :
                        mimeTools (2.8)
                        NppConverter (4.4)
                        ComparePlus (1)
                        PythonScript (2)
                    The command line set gives :
                    ALLUSERSPROFILE=C:\ProgramData
                    APPDATA=C:\Users\Guy\AppData\Roaming
                    BRB=C:\Program Files\HP\Sure Click\bin
                    BRS=C:\Program Files\HP\Sure Click\servers
                    CommonProgramFiles=C:\Program Files\Common Files
                    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
                    CommonProgramW6432=C:\Program Files\Common Files
                    COMPUTERNAME=GUYTOU
                    ComSpec=C:\windows\system32\cmd.exe
                    DriverData=C:\Windows\System32\Drivers\DriverData
                    FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
                    FPS_BROWSER_USER_PROFILE_STRING=Default
                    HOMEDRIVE=C:
                    HOMEPATH=\Users\Guy
                    LOCALAPPDATA=C:\Users\Guy\AppData\Local
                    LOGONSERVER=\\GUYTOU
                    NUMBER_OF_PROCESSORS=8
                    OneDrive=C:\Users\Guy\OneDrive
                    OnlineServices=Online Services
                    OS=Windows_NT
                    Path=: E:\846_x64_RC3\notepad++.exe
                    PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
                    platformcode=AN
                    PROCESSOR_ARCHITECTURE=AMD64
                    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 140 Stepping 1, GenuineIntel
                    PROCESSOR_LEVEL=6
                    PROCESSOR_REVISION=8c01
                    ProgramData=C:\ProgramData
                    PROMPT=$P$G
                    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\windows\system32\WindowsPowerShell\v1.0\Modules
                    PUBLIC=C:\Users\Public
                    RegionCode=EMEA
                    SESSIONNAME=Console
                    SystemDrive=C:
                    SystemRoot=C:\windows
                    TEMP=C:\Users\Guy\AppData\Local\Temp
                    TMP=C:\Users\Guy\AppData\Local\Temp
                    USERDOMAIN=GUYTOU
                    USERDOMAIN_ROAMINGPROFILE=GUYTOU
                    USERNAME=Guy
                    USERPROFILE=C:\Users\Guy
                    windir=C:\windows
                    ZES_ENABLE_SYSMAN=1
                    Terry RT Alan KilbornA 2 Replies Last reply Reply Quote 1
                    • guy038G guy038 referenced this topic on
                    • Terry RT Offline
                      Terry R @guy038
                      @guy038 said in Strange behavior of the sort function, with zero-length column mode selection:
                      However, I do not understand why IF I select again the Plugins > PythonScript > New Script option, this time, the Save under… windows proposes to save the future .py file in the \E folder instead of the normal location E:\846_x64_RC3\plugins\Config\PythonScript\Scripts ?!
                      After reading that I’m wondering if a variable has been set if the first use was in relation to the E:\ drive. Now any successive use of this will use the pre-set variable of E:\ as a starting point since it’s already set.
                      Possibly a test might be to complete a fresh start of NPP and do a new script and see what the Save Under proposes.
                        Alan Kilborn @guy038
                        @guy038
                        I also have problems with the PythonScript > New Script command suggesting a folder that isn’t the one I want. It typically suggests a folder that is the scripts folder for another version of Notepad++ that I’ve recently used. I’ve no idea why this happens; I’ve posted about this before but never came to a resolution. So…I’m just doubly careful when I save a new script, such that it is going into the correct folder!
                        • guy038G Offline
                          Hi All,
                          Could it be connected with the fact of putting a local N++ install on a removable drive ?
                          • guy038G Offline
                            Hi, @terry-r, @alan-kilborn, @peterjones and All
                            I’m really perplexed !!??
                            • On my USB drive, I created a new folder E:\846_x64
                            • Then, I moved the npp.8.4.6.portable.x64.7z archive, that I kept, from the folder E:\846_x64_RC3 to the new folder E:\846_x64
                            • I opened this archive and extracted all the contents in the E:\846_x64 folder
                            • I defined my preferred parameters in Settings > Preferences...
                            • And I downloaded the PythonScript plugin via the Plugin Admin
                            Bingo ! I’m pleased to tell you that, whatever the current tab, as soon as I select the Plugins > PythonScript > New Script option, the Save inder window always opens in E:\846_x64\plugins\Config\PythonScript\Scripts ;-))
                            • Finally, I added the ComparePlus and BetterMultiSelection plugins and everything is still OK !
                            So, I don’t see why it’s OK on a local N++ install, in folder E:\846_x64 and KO on a SAME local N++ install, in folder E:\846_x64_RC3 ???
                            Anyway, my problem is solved !
                            …A quarter of an hour later, even if I use my old local N++ version, within the E:\846_x64_RC3 folder, everything seems OK, again ??? Really confusing !
                            • guy038G Offline
                              Hi all,
                              As promised, I created a new issue concerning this problem :
                              https://github.com/notepad-plus-plus/notepad-plus-plus/issues/12299#issue-1401062911
                              • guy038G Offline
                                Hello @alan-kilborn and All,
                                In the post above, of this discussion :
                                https://community.notepad-plus-plus.org/post/80361
                                You said that you met the problem, sometimes in the past and that you haven’t find a solution yet to the fact that running the Plugins > PythonScript > New Script does not open the folder Local N++ install\Plugins\Config\PythonScript\Scripts, in the case of a local N++ install !
                                I’ve already found out two ways to reproduce this wrong behavior and also how to get the right folder ! Could you, Alan, @peterjones or someone else confirm my hypotheses ?
                                A wrong folder destination, when using the Plugins > PythonScript > New Script option, may occur when :
                                • You’re trying, by mistake, to open an already opened file in your current N++ session which is not saved in the ...\Plugins\Config\PythonScript\Scripts folder
                                • You’re saving a new_x file, in a specific folder, different from the ...\Plugins\Config\PythonScript\Scripts folder
                                So, an easy solution is to re-open a Python script of your current session ! Afterwards, any use of the Plugins > PythonScript > New Script option should open the right folder ...\Plugins\Config\PythonScript\Scripts ;-))
                                Remark : Note that holding the Ctrl key, while using the Plugins\Python Scripts\Scripts\"Script Name" option, does not help in this matter :-((
                                  As I never do those two actions, that isn’t a way I’m getting into the circumstance.
                                  My problem with it mainly occurs when I am running a different instance of N++ to test a script in a “clean” setup. I tell it to create a New Script and it wants to save the file in the correct folder but in my daily use Notepad++.
                                  I have several workarounds for this, but it is annoying behavior to say the least.
                                    The “Strange behavior of the sort function, with zero-length column mode selection” has been SOLVED by the developers and will be in the next release, presumably 8.4.8.
                                      @PeterJones :
                                      In Peter’s Oct 6, 2022 11:20am posting, the script code contained this line:
                                      if editor.getSelectionMode()<>SELECTIONMODE.RECTANGLE:
                                      Is Peter showing his BASIC roots here by using <>?
                                      Proper Python would be to use != (or so one would think… keep reading…).
                                      What caused me to notice this is that I exclusively use Python3 (and PythonScript v3.x) these days, and such a thing causes an error there, e.g.
                                      Python 3.12.3 (tags/v3.12.3:f6650f9, Apr  9 2024, 14:05:25) [MSC v.1938 64 bit (AMD64)]
                                      >Initialisation took 3078ms
                                      >Ready.
                                      >>> a = 3
                                      >>> a <> 4
                                        File "<console>", line 1
                                          a <> 4
                                      SyntaxError: invalid syntax
                                      This made me dig up PythonScript 2 and try it there, where, indeed, it is fine:
                                      Python 2.7.18 (v2.7.18:8d21aa21f2, Apr 20 2020, 13:25:05) [MSC v.1500 64 bit (AMD64)]
                                      >Initialisation took 2703ms
                                      >Ready.
                                      >>> a = 3
                                      >>> a <> 4
                                      True
                                      Probably the moral to the story is to just not use <> with Python, whatever version. :-)
                                      Perhaps some further interesting reading: https://stackoverflow.com/questions/16749121
                                        100 PRINT "BASIC FOREVER"
                                        200 GOTO 100
