    Preferred way to work with INI files
    4 Posts 2 Posters 981 Views
    • Chris De BoeckC
      Chris De Boeck
      Hi,
      I would like to work with a separate INI file, but is there a preferred way within the ‘plugin world of npp’ to work with INI / property files? Like specific libraries or something?
      Thanks,
      Chris
        Ekopalypse @Chris De Boeck
        @Chris-De-Boeck
        A plugin can be written in different languages, so I guess it depends on what your preferred language offers, I guess.
        Chris De BoeckC 1 Reply Last reply Reply Quote 0
        • Chris De BoeckC
          Chris De Boeck @Ekopalypse
          @Ekopalypse
          I would be using C++
            @Chris-De-Boeck
            Unfortunattely I don’t know much about cpp. But there is GetPrivateProfileString, not sure if this works for you.
