    Cursor setting - deletes next letter
    3 Posts 2 Posters 1.7k Views
    • George MasterG
      George Master
      I didn’t find this issue, as I don’t know how to describe it.
      I had it once before, and got it solved after going thru all the settings, but I don´t know how I did it and where to find it:
      All of a sudden, the cursor is not a vertical, but a horizontal blinking line, and if you want to insert a letter, it will allow that but will delete the next one. The letter next to the inserted one will be erased…
      Which setting is responsible for this?
      Thanks…
        Ekopalypse @George Master
        @George-Master
        You probably pressed the Insert key and this changed it to overwrite mode. Press the key again or click on the last section of the status bar, which is probably called OVR and should change to INS
        • George MasterG
          George Master
          hey thats so easy
          thanks, now I will know from now!
