    Need Help For Remove a href Tag With out remove anchor Text
    2 Posts 2 Posters 607 Views
    • S
      Smart Warriors
      <a href=“site.com”>hello</a>
      Need Only "Hello"Text From Above HTML CODE How to do Using Regular Experssion
        Hello, @smart-warriors and All,
        If we assume that the strings <a href= and </a> are, both, on one line, only, I suppose that the following regex does the job :
        • SEARCH (?s)<a href=.+?>\K.+?(?=</a>)
        • Possibly, check the Wrap around option
        • Then, click on the Copy Marked Text button
        • Open a new tab ( Ctrl + N )
        • Paste the clipboard’s contents ( Ctrl + V )
        If all your <a href=.....>........</a> definitions are contained in a single line, you may use the more restrictive regex :
        MARK (?-s)<a href=.+?>\K.+?(?=</a>)
