    imported 3 UDL for AHK removed 2 still 3 entries
    2 Posts 2 Posters 324 Views
    • Peer GyntP
      Peer Gynt
      Hi Everybody,
      pretty new to using NPP. I want to use npp for editing Autohotkey-scripts. So I searched for a dark theme for AHK.
      I found 2 files and imported them but they were not for a dark theme.
      So I searched again and found this one
      https://www.autohotkey.com/boards/viewtopic.php?t=72424
      I installed this file to into subfolder
      C:\Users\choic\AppData\Roaming\Notepad++\userDefineLangs
      then I deleted the two other files
      Still npp shows me 3 entries and only one (the wrong one) is choosable
      What do I have to do to remove the 2 wrong entries in the menu to enable the right one?
      thank you very much in advance for assistance
      cheers from Peer
        PeterJones @Peer Gynt
        @Peer-Gynt ,
        Did you exit Notepad++ and re-start it after removing the old files?
        If that doesn’t work, go into the User Defined Language dialog, select each of the “AutoHotkey” languages and click Remove. Restart notepad++ and make sure they are all gone. Then re-save the dark-mode-AHK into the userDefineLangs folder, exit Notepad++ and restart. There should only be one now.
        (If you put the XML into the userDefineLangs folder, you do not ever have to use the Import button in the User Defined Language dialog)
