    Replace the comma between two selected words using regex replacement
    4 Posts 2 Posters 2.2k Views 1 Watching
    • voska7V Offline
      voska7
      I want to replace the comma (,) between two selected words. here is the input
      test normal content [ABC]new, ball, test[/ABC]
      output
      test normal content [ABC]new[/ABC][ABC] ball[/ABC][ABC] test[/ABC]
      can someone please guide me on how to do it?
        Alan Kilborn @voska7
        @voska7
        If you know about the existence of regex, why is this hard?
        Find: ,
        Replace: [/ABC][ABC]
        voska7V 1 Reply Last reply Reply Quote 0
        • voska7V Offline
          voska7 @Alan Kilborn
          @Alan-Kilborn i want to replace comma only inside [ABC] [/ABC]. I could not able to edit the first post.
          input
          test, normal content [ABC]new, ball, test[/ABC]
          Output
          test, normal content [ABC]new[/ABC][ABC] ball[/ABC][ABC] test[/ABC]
          sorry I did not explain properly in my first post.
            @voska7 said in Replace the comma between two selected words using regex replacement:
            If you go to the FAQ on this site…
            And from there go HERE…
            One of the choices there will take you HERE…which seems to be what you need.
