    Search Window Double Click Function
    2 Posts 2 Posters 337 Views
    • Win CustomW
      Win Custom
      Hi,
      Search window goto file and highlight feature stopped working for me. It only works the first time you do it after launching NPP. But the second time you do a search, you can’t double click anymore to go to the file and highlight. I have a video demonstrating this.
      Thanks!
      alt text
        PeterJones @Win Custom
        @Win-Custom ,
        This sounds like the known issue here (@Yaron can correct me if I’m wrong). If so, it will be fixed in the next revision of Notepad++.
