    help for quotes please
    4 Posts 3 Posters 286 Views
    • Bastien AllouardB
      Bastien Allouard
      Hello, I’m making a mod where I translate a game into French and I need to replace words in quotes with words translated into French, example
          Hyping "Hyping"
          Fulfillingcontract "Fulfilling contract"
          Time-limit "Time-limit"
          Requiredquality "Required quality"
          Upfront "Upfront"
          Whendone "When done"
          Penalty "Penalty"
          Costperbug "Cost per bug"
          Bugpenalty "Bug penalty"
          Latepenalty "Late penalty"
          Qualitypenalty "Quality penalty"
          Cancelpenalty "Cancel penalty"
          Netprofit "Net profit"
          Delivered "Delivered"
          Maxbandwidth "Max bandwidth"
          Lookagain "Look again"
          LookAgainPrompt "Are you sure you want to look again? It will cost {0}"
      to
          Hyping "Popularité"
      	Fulfillingcontract "Contrat rempli"
      	Time-limit "Limite de temps"
      	Requiredquality "Qualité requise"
      	Upfront "Avance"
      	Whendone "A la livraison"
      	Penalty "Penalté"
      	Costperbug "Coût par bug"
      	Bugpenalty "Pénalité des bugs"
      	Latepenalty "Pénalité de retard"
      	Qualitypenalty "Pénalité de Qualité"
      	Cancelpenalty "Pénalité d'annulation"
      	Netprofit "Profit net"
      	Delivered "Livré"
      	Maxbandwidth "Bande passante Max"
      	Lookagain "Actualiser"
      	LookAgainPrompt "Êtes-vous sûr de vouloir actualiser ? Cela vous coûtera {0}"
      I just wish I could take the words in quotes and be able to paste them in once translated
      Bastien AllouardB 1 Reply Last reply Reply Quote 0
      • Bastien AllouardB
        Bastien Allouard @Bastien Allouard
        @Bastien-Allouard
        like just take
        "Popularité"
        "Contrat rempli"
        "Limite de temps"
        "Qualité requise"
        "Avance"
        "A la livraison"
        "Penalté"
        "Coût par bug"
        "Pénalité des bugs"
        "Profit net"
        "Livré"
        "Actualiser"
        and paste in a once after the english’s words like
            Hyping
        	Fulfillingcontract
        	Time-limit
        	Requiredquality
        	Upfront
        	Whendone
        	Penalty
        	Costperbug
        	Bugpenalty
        	Latepenalty
        	Qualitypenalty
        	Cancelpenalty
        	Netprofit
        	Delivered
        	Maxbandwidth
        	Lookagain
        	LookAgainPrompt
        to give
            Hyping "Popularité"
        	Upfront "Avance"
        	Penalty "Penalté"
        	Delivered "Livré"
          PeterJones @Bastien Allouard
          @Bastien-Allouard ,
          Natively in Notepad++? The only way is manual search/replace for each term (or craft a regex that essentially does the same).
          If you are willing to use the PythonScript plugin, then this post has an example of a script that will translate from English to another language; just put your English terms/phrases on the left side of the translation table, and the French equivalents on the right side.
            Hello, @bastien-allouard, @peterjones and All,
            I’ve got a solution which needs the installation of the excellent BetterMultiSelection plugin, from @dail ! So :
            • Open the menu option Plugins > Plugins Admin...
            • Select the BetterMultiSelection plugin
            • Click on the Install button
            • Click on the Close button
            • For security, close and restart Notepad++
            Now, assuming that you have this INPUT text :
                Hyping "Hyping"
                Upfront "Upfront"
                Penalty "Penalty"
                Hyping "Popularité"
                Upfront "Avance"
                Penalty "Penalté"
                Delivered "Livré"
            • First, let’s change any tab char by the corresponding space chars with the menu option Edit > Blank Operations > TAB to Space
            • Select all the lines, English and French
              • SEARCH (?-s)^(\h*).+?"
              • REPLACE \1"
              • Tick the Wrap around and In selection options
            You should obtain the OUTPUT text below :
                "Hyping"
                "Time-limit"
                "Required quality"
                "Upfront"
                "When done"
                "Penalty"
                "Cost per bug"
                "Bug penalty"
                "Late penalty"
                "Quality penalty"
                "Cancel penalty"
                "Net profit"
                "Delivered"
                "Max bandwidth"
                "Look again"
                "Popularité"
                "Contrat rempli"
                "Limite de temps"
                "Qualité requise"
                "Avance"
                "A la livraison"
                "Penalté"
                "Coût par bug"
                "Pénalité des bugs"
                "Profit net"
                "Livré"
                "Actualiser"
            • Enable, if necessary, the BetterMultiSelection plugin
            • Do a zero-length rectangular selection of all the lines ( Hit, simultaneously the Alt and Shift keys and press the Down key, several times )
            • Release all the keys, then hit the End ( or Fin ) key
            => All the cursors should be at the end of lines
            • Hit the Enter key to insert blank lines, in between
            • Hit the Backspace key to delete the tabulations ( IMPORTANT )
            • Hit the Esc key to disable your rectangular selection
            You’ll get this OUTPUT :
                "Hyping"
                "Time-limit"
                "Required quality"
                "Upfront"
                "When done"
                "Penalty"
                "Cost per bug"
                "Bug penalty"
                "Late penalty"
                "Quality penalty"
                "Cancel penalty"
                "Net profit"
                "Delivered"
                "Max bandwidth"
                "Look again"
                "Popularité"
                "Contrat rempli"
                "Limite de temps"
                "Qualité requise"
                "Avance"
                "A la livraison"
                "Penalté"
                "Coût par bug"
                "Pénalité des bugs"
                "Profit net"
                "Livré"
                "Actualiser"
            • Now, redo a zero lengh rectangular selection of the french lines only, including the blank ones
            • While keeping pressed the Alt and Shift keys, hit the End ( or Fin ) key to include all text
            • Press the Ctrl + X shortcut, to move that text in the clipboard
            • Hit the Esc key to disable the rectangular selection
            • Now, move the caret at the very beginning of the first blank line, under the line "Hyping"
            • Hit the Ctrl + V shortcut
            => Wow ! you should get this OUTPUT text, below :
                "Hyping"
                "Popularité"
                "Contrat rempli"
                "Time-limit"
                "Limite de temps"
                "Required quality"
                "Qualité requise"
                "Upfront"
                "Avance"
                "When done"
                "A la livraison"
                "Penalty"
                "Penalté"
                "Cost per bug"
                "Coût par bug"
                "Bug penalty"
                "Pénalité des bugs"
                "Late penalty"
                "Quality penalty"
                "Cancel penalty"
                "Net profit"
                "Profit net"
                "Delivered"
                "Livré"
                "Max bandwidth"
                "Look again"
                "Actualiser"
            Finally, do the last regex S/R, below :
            • SEARCH (?-s)^(\h*)"(.+)"\R\h*(.+)
            • REPLACE \1\2\x20\3
            This regex selects two lines and rewrites all chars of the first line, but the double quote chars. Then, changes the EOL, between the two lines, with a space char and, finally, rewrites the contents of the second line
            So, you should get your expected OUTPUT text :
                Hyping "Popularité"
                Fulfilling contract "Contrat rempli"
                Required quality "Qualité requise"
                Upfront "Avance"
                When done "A la livraison"
                Penalty "Penalté"
                Cost per bug "Coût par bug"
                Bug penalty "Pénalité des bugs"
                Late penalty "Pénalité de retard"
                Quality penalty "Pénalité de Qualité"
                Cancel penalty "Pénalité d'annulation"
                Net profit "Profit net"
                Delivered "Livré"
                Max bandwidth "Bande passante Max"
                Look again "Actualiser"
                Are you sure you want to look again? It will cost {0} "Êtes-vous sûr de vouloir actualiser ? Cela vous coûtera {0}"
