    Install Plugins without Admin Rights and Internet Connection - Manual Way doesn't work.
    13 Posts 5 Posters 13.6k Views
    • P FueP
      P Fue
      Hello all,
      I’ve tried different ways:
      • change install path, where users have rights to write
      • install plugin manually (start Notepad++ with admin rights - import plugin dll - restart Notepad++ --> there was no plugin in the menu installed
      • Version Notepad++ 8.4.2 64 Bit
      Please help with further tips or tricks.
        Alan Kilborn @P Fue
        @p-fue
        Which plugin are you trying, and where did you obtain it?
        Have you tried simply placing the DLL file (assuming a simple plugin that just needs its DLL file) into the proper plugins folder manually, meaning copying the file to the right place using Windows File Explorer?
        Proper folder structure would be ...\plugins\XXX\XXX.dll for a plugin named XXX.
        P FueP 1 Reply Last reply Reply Quote 1
        • P FueP
          P Fue @Alan Kilborn
          @alan-kilborn
          For example HTML Tag OR XML Tools
          This website: https://sourceforge.net/projects/npp-plugins/files/HTMLTag/HTMLTag plugin v1.0.0/
          It is not the newest version of the plugin.
          Yes on this way I tried it.
          First time in the Program Files Path and on the second time with an path where the user has the rights to write.
          I get always the result message --> It was successfull please restart notepad++ - but after the restart there is no plugin.
          Alan KilbornA P FueP 3 Replies Last reply Reply Quote 0
            Alan Kilborn @P Fue
            @p-fue said in Install Plugins without Admin Rights and Internet Connection - Manual Way doesn't work.:
            You wouldn’t get this message if trying my suggestion of manually copying the file into the appropriate place, so I can’t tell if you are actually trying that or not. Maybe it is a language barrier.
            P FueP 1 Reply Last reply Reply Quote 0
            • P FueP
              P Fue @P Fue
              Further information:
              Notepad++ creates an folder called HTML Tag with includes the dll file.
              But in notepad++ there is nothing shown.
              • P FueP
                P Fue @Alan Kilborn
                @alan-kilborn
                I read, that sometimes the message can come or not.
                This is my manual: https://okidk.de/notepad-plugins-konnen-unter-windows-10-nicht-installiert-werden/
                I do Method 5.
                This message I get:
                  Alan Kilborn @P Fue
                  I looked at that.
                  That version is really old.
                  It might just be that that version is incompatible with a more modern (e.g. 8.4.2) Notepad++.
                  If it were me, I would not try to use that version of the plugin.
                    PeterJones @P Fue
                    @p-fue ,
                    If you want to do a manual installation of HTML Tag plugin:
                    1. Note that the Plugins Admin lists the now-official home of HTML Tag as https://bitbucket.org/rdipardo/htmltag/ , not that ancient sourceforge link; and that points to https://bitbucket.org/rdipardo/htmltag/downloads/ as the downloads location
                    2. Download the zip file for the 64bit plugin
                    3. unzip the plugin to a temporary location
                    4. Do not use the Settings > Import > Import plugin(s). Exit Notepad++.
                    5. Create a new folder ...<notepad++install-location>\Plugins\HTMLTag\
                    6. Copy all the files from the temporary location to ...<notepad++install-location>\Plugins\HTMLTag\
                    7. Restart Notepad++
                    8. The plugin will be in the Plugins menu if you have followed these correctly
                    The only time that Settings > Import > Import plugin(s) works is if your plugin only has a DLL and no other files; the HTMLTag has other files, so Settings > Import DLL will not work, because it will not put the other files in the right place.
                    P FueP inmizi mizI 2 Replies Last reply Reply Quote 3
                    • P FueP
                      P Fue @PeterJones
                      @peterjones
                      Great - it works!
                      Do you have other download-links for these plugins?
                      • Compare
                      • HEX-Editor
                      • Npp Xml Treeview
                      • XML Tools
                      Thanks for your help.
                        Alan Kilborn @P Fue
                        You can find download links embedded in the data here:
                        • https://github.com/notepad-plus-plus/nppPluginList/blob/master/src/pl.x64.json (64-bit)
                        • https://github.com/notepad-plus-plus/nppPluginList/blob/master/src/pl.x86.json (32-bit)
                        • inmizi mizI
                          inmizi miz @PeterJones
                          rdipardoR 1 Reply Last reply Reply Quote 1
                          • rdipardoR
                            rdipardo @inmizi miz
                            Off-topic, but worth pointing out to future visitors of this thread. When @inmizi-miz quoted Peter’s reply, the link to the plugin repository was mangled so that, bizarrely, the /downloads path segment redirects to a commercial website selling light fixtures (*):
                            Rest assured the link text is correct; just make sure to paste it into your browser’s address bar.
                            (*) Looks like someone’s clipboard history got pasted into an accidentally summoned “Edit Hyperlink” pop-up window
                            • rdipardoR rdipardo referenced this topic on
                              PeterJones @rdipardo
                              @rdipardo ,
                              It’s actually a new form of spam that I noticed in a few other posts – by that same user, and a couple others. The posts have been removed, and the posters flagged. (I hadn’t noticed at the time that it was the same user or that links had been edited)
