    NppGtags occur "vector<T> too long" with v8.4 and later
    6 Posts 3 Posters 2.5k Views 1 Watching
    • Goldfish VillageG Offline
      Goldfish Village
      I use “Find Definition” of NppGtags with Notepad++ 8.4 and later will occur “vector<T> too long” issue, but 8.3.3 without the issue, Anyone see some issue?
      Alan KilbornA Michael VincentM 2 Replies Last reply Reply Quote 0
      • Alan KilbornA Online
        Alan Kilborn @Goldfish Village
        @goldfish-village
        Probably THIS will cover the problem you are experiencing, but you might want to show your Debug Info.
        Goldfish VillageG 1 Reply Last reply Reply Quote 0
          Goldfish Village @Alan Kilborn
          @alan-kilborn said in NppGtags occur "vector<T> too long" with v8.4 and later:
          @goldfish-village
          Notepad++ v8.4.2 (32-bit)
          Build time : May 29 2022 - 16:45:17
          Command Line : “\MXUSER4\www\StockCafe\Workplace.npp”
          OS Version : 21H2
          OS Build : 19044.1766
          Current ANSI codepage : 950
          Plugins :
          NppGTags (4.5)
          • Michael VincentM Offline
            Michael Vincent @Goldfish Village
            @goldfish-village said in NppGtags occur "vector<T> too long" with v8.4 and later:
            Probably wise to open an issue on the NppGTags GitHub.
            Goldfish VillageG 1 Reply Last reply Reply Quote 2
              Goldfish Village @Michael Vincent
              @michael-vincent Thanks, I got response from GitHub
                Great - @pnedev is a very responsive developer, pretty sure there’d be a fix soon, if not one already (which I seems like there was).
