    SOS HELP With 2nd Instance
    2 Posts 2 Posters 326 Views
    • Niko HamilN
      Niko Hamil
      Hello all
      I had several tabs in both views of Notepad++
      and then i opened an instance and I added some code in a few tabs in the Instance too
      Computer crashed
      I re-open Notepad++
      Main window all tabs ok
      Instance window… GONE !
      Backup folder and Session.xml checked but they dont seem to be there
      Any chances ?
      Instance disappears after pc crash ?
      Thanks
        PeterJones @Niko Hamil
        @niko-hamil ,
        Unfortunately, as you may have surmised from the resounding silence, there is not much you can do: if the periodic unsaved-file “backups” aren’t in their folder, then the crash caused Notepad++ to exit during the brief time that the files didn’t exist (or you didn’t have the unsaved-file backups option turned on)
        For the future, I recommend saving your files to known locations frequently, rather than leaving them opened-and-unsaved. For more, see our backup FAQ
