    Help with encoding
    2 Posts 2 Posters 273 Views
    • Luis Piña IIIL
      Luis Piña III
      I set my document to UTF-8 with BOM and am trying to use:
      Instead I get some squares.
        PeterJones @Luis Piña III
        @luis-piña-iii ,
        Generally, an unexpected square in your document on a unicode character means that the current font doesn’t have a glyph for that character. You might try toggling the Settings > Preferences > MISC > ☐ Use DirectWrite (May improve rendering special characters, need to restart Notepad++) – this often makes such glyph issues work better by allowing the OS to do behind-the-scenes things to borrow a glyph from a different font for that character.
        If that doesn’t work, you might investigate changing Settings > Style Configurator > Global Styles > Default style’s Font setting, and see if another font will properly render the glyph that your current font does not.
