    Comparing issue
    Scheduled Pinned Locked Moved Blogs
    2 Posts 2 Posters 910 Views
    • Manish ThukralM
      Manish Thukral
      Hi i am having comparing issue. when i compare two files then Notepad++ goes to be closed
        PeterJones @Manish Thukral
        @manish-thukral ,
        You need to make sure you have the right version of the Compare plugin for your version of Notepad++. Check the Plugins Admin for updates on the plugin. (Specifically, if you are at NPP v8.3 or newer, you must use Compare Plugin 2.0.2 or it will not work right.)
