    Code folding help
    5 Posts 2 Posters 535 Views
    • VindicitV
      Vindicit
      So Im trying to use code folding. I’m not sure what language I am working with so I am trying to create my own language setting. My open line in the code looks like “Macro XXXXXXX” my end code is just “End”. So my open fold is just “Macro”.
      |Macro XXXXXX
      |mid
      |mid
      |End
      The issue I’m having is within the code there is “Attribute End” and “End Object” which is hanging up the end fold. How do I specify my closing fold as just “End” by itself with a new line afterwards?
        PeterJones @Vindicit
        @vindicit ,
        Unfortunately, as far as I know, you cannot do that by itself.
        The logic for determining the folding is pretty simple, and cannot handle restricted cases such as that. (It was more designed with simple pairs like if / endif in mind, where there is no ambiguity.)
        However, if you can nest something like "attribute begin" / "attribute end" inside, then you could set
        OPEN = "attribute begin" macro
        CLOSE = "attribute end" end
        then this text
        blah
        macro
        attribute begin
        attribute end
        end
        blah
        will fold as:
        … so the attribute begin / attribute end is a nested fold inside of the other
        But that requires that anything with “end” in it be able to be added in the list (and the one that’s just-plain-“end” has to be the last version in the list).
        • VindicitV
          Vindicit
          Thanks Ill take a look at that.
          • VindicitV
            Vindicit
            So I took a look at the code and it has as an example
            Macro XXXXX
            Begin Object XXX
            Attributes Beg
            Attributes End
            End Object XXX
            End
            So In the folding in code 2 style I have
            Macro “Begin Object” “Attributes Beg”
            In close I have
            “End Object” “Attributes End” End
            Does this look right? It seems to work.
              @vindicit ,
              If it works for you, that’s the important thing. I always keep the pairs in the same order, so I would have said OPEN = "begin object" "attributes beg" macro and CLOSE = "end object" "attributes end" end so that the object-pair were the first tokens in each, the attributes-pair were the second tokens in each, and the macro-pair were the third tokens in each. But that doesn’t seem to be required.
