    Notepad++ 8.4 Release - Keep standing up for Ukraine
    25 Posts 10 Posters 13.1k Views
    • F
      ffgmusik
      Hi!
      The default colors of html and php codes in the editor do not work as expected.
      PeterJonesP rdipardoR 2 Replies Last reply Reply Quote 0
        PeterJones @ffgmusik
        @ffgmusik ,
        The PHP lexer renders tag names using the Style Configurator > PHP > DEFAULT style. And the initial setting for that style is black text on white background, which is what your screenshot shows.
        The HTML would render similar text slightly differently:
        This is because it uses the HTML > TAG style for rendering tag names:
        • rdipardoR
          rdipardo @ffgmusik
          @ffgmusik,
          previous Notepad++ versions did automatically activate HTML tag highlighting when opening PHP files (as well as *.asp and *.jsp files):
            else if ((type == L_HTML) || (type == L_PHP) || (type == L_ASP) || (type == L_JSP))
               execute(SCI_SETLEXER, SCLEX_HTML);
          The code providing this feature was accidentally removed during the Scintilla 5 upgrade, just before the 8.4 release. It will work again in the next release: https://github.com/notepad-plus-plus/notepad-plus-plus/commit/2fbac354ed00a7723b18f688f922a2ffb114cb13
          • Kevin SmileyK
            Kevin Smiley
            Notepad++ 8.4 “Print Selection” is printing the selected text along with highlights as shown on screen making the print hard to read as it is black text with dark grey background on a black and white printer. We have uninstalled, and moved back to Notepad++ 8.3.3 and the issue is no longer present.
            • donhoD donho unpinned this topic on
            • F
              ffgmusik
              I found a problem with the scroll in version 8.4 and needed to go back to the previous version (8.3.3). I use a laptop and a touchpad. The page instead of going line by line, rolls several lines at the same time obstructing the view of the code. In version 8.3.3 this problem does not occur.
              I have already changed the options in settings > preferences > editing and do not resolve.
              • rdipardoR rdipardo referenced this topic on
              • PeterJonesP PeterJones locked this topic on
