    Document does not scroll when holding F3
    4 Posts 3 Posters 395 Views
    • Antoni RoszakA
      Antoni Roszak
      Hi,
      In the recent update (perhaps in 8.3.3 but I am not 100% sure) NPP changed the behaviour of F3 button.
      Before, I was able to hold F3 and quickly go through the whole file.
      Now, when I hold F3, the vertical scrollbar shows it’s progressing, but the document itself is frozen. Only when I release the button, it jumps to the position in file indicated by scrollbar.
      I suppose this is a bug, as I see no advantage of the new behaviour; is it the right category to request fixing it?
      Notepad++ v8.3.3 (64-bit)
      Build time : Mar 13 2022 - 17:20:02
      Command Line :
      OS Version : 2009
      OS Build : 19042.1586
      Plugins : ComparePlugin.dll JSMinNPP.dll mimeTools.dll NppConverter.dll NppExport.dll NppHorizontalRuler.dll NppRegExTractorPlugin.dll XMLTools.dll
      • dfs-D
        dfs-
        Works fine for me with the same version
        Command Line :
        OS Version : 2009
        OS Build : 19044.1620
        Plugins : ComparePlugin.dll JSMinNPP.dll mimeTools.dll NppConverter.dll NppExport.dll PythonScript.dll XMLTools.dll
        Possibly a plugin is interfering, what does NppHorizontalRuler.dll do?
          Michael Vincent @Antoni Roszak
          @antoni-roszak said in Document does not scroll when holding F3:
          I can only assume this is an XML file and yo need to update your XML Tools to the latest version (3.1.1.13 as of this comment) as this is a known issue with older versions.
          • Antoni RoszakA
            Antoni Roszak
            Hi,
            I have uninstalled the Horizontal Ruler, and updated XMLTools to 3.1.1.13, and it’s still incorrect. This is a large XML file, 57 MB, 1.7 million lines. With a smaller file (87k lines) it works fine.
            I have narrowed it down a bit; apparently, the problem occurs when the number of lines between occurrences is large. I cannot share the original file itself for privacy reasons, but I got the path:
            • take file “C:\Windows\Microsoft.NET\DirectX for Managed Code\1.0.2911.0\Microsoft.DirectX.Direct3DX.xml”
            • copy everything between second and penultimate line, 20 times (I got 270k lines)
            • search for “Microsoft.DirectX.PrivateImplementationDetails.”, normal mode
            • hold F3
