    one corner case where npp doesn't warn about "{file} doesn't exist anymore"
    13 Posts 5 Posters 4.5k Views 3 Watching
    • MM-JohnM Offline
      MM-John
      In the normal case:
      If you edit a file in npp.
      Then go to another window and delete it (or rename it).
      Then come back to npp.
      It warns you:
      {file} doesnt exist any more. Keep file in editor?
      If you say ‘yes’, then the file is marked as modified.
      If you then close, you get a prompt to save the file.
      These are nice, helpful warnings that have saved me lots of time and re-work (thanks!).
      However there’s one particular sequence which avoids these warnings. Admittedly, it’s a corner case:
      Edit a file in npp.
      In npp do: file -> open
      It will default to the current file’s directory (folder) (or navigate there).
      rename the npp current file on disk from within in the file-open dialog box (I tested on windows only).
      ESC out of file-open.
      You are now back to npp with the current file in focus.
      However, now there is no file on written to disk corresponding to this buffer.
      You do not get a warning that the file doesn’t exist.
      (If you go to a different window and come back, you do.)
      And so the file is not marked as modified.
      Now if you close the file (without leaving npp), you get no prompt to save file.
      I think the issue is that it’s npp coming back in focus that triggers the check for “are all buffers still written to disk files.” And this particular sequence avoids npp changing out and back into focus.
      Another scenario might be a 2nd party (human remotely logged in, automated process) deleting a file while you’re working on it in npp.
      So, as I said, this is a corner case. I don’t expect anyone to fix it, I just thought it ought to be documented.
      Couple side notes:
      I have a process where I do this sequence because I sometimes like to save a file as a backup file, and rename is a good way of doing that preserving create/modify date-times, and doing it in the npp file-open dialog is convenient.
      Secondly, I noticed this because (for which I plan to create another post) I have started to hit Alt+X by accident. Alt+X appears to be an undocumented/unreported keyboard shortcut for file -> close (also ctrl+w). I hit Alt+X by accident these days because I installed the ‘XML Tools’ plugin which can be accessed via Alt+P, X and I’ve been hiting Alt+X as a typo lately.
      MM-JohnM Neil SchipperN 2 Replies Last reply Reply Quote 0
      • MM-JohnM Offline
        MM-John @MM-John
        FYI that was npp v8.3.3 64bit portable.
        • Neil SchipperN Offline
          Neil Schipper @MM-John
          @mm-john said in one corner case where npp doesn't warn about "{file} doesn't exist anymore":
          I used to do that, but at some point I started to make use of File commands “Save a Copy As…” and Rename (latter also in tab right-click) which feel a bit safer because they’re not “sneaky”, ie, outside NPP’s awareness.
          MM-JohnM 2 Replies Last reply Reply Quote 2
          • MM-JohnM Offline
            MM-John @Neil Schipper
            @neil-schipper Absolutely that’s an option. But that file has today’s date, not the original date of the file. For me that’s an important distinction.
            • MM-JohnM Offline
              @neil-schipper Also, another alternative is File - Rename to backup file name. Then File -> save_as to original file name. That’s equivalent to what I’m doing. I find the file - open easier, but they’re close.
                Alan Kilborn @MM-John
                @mm-john
                I understand the complaint. You should make a real issue out of it; see instructions HERE.
                As to your workflow, if your intent is to make a backup, why wouldn’t you copy the file to a new name rather than renaming it? You could even do this right in the File > Open dialog, as an alternative to the renaming operation you are doing now. This would seem to solve your problems (in the context of your workflow – it doesn’t solve anything about the issue with N++).
                  Alan Kilborn @Alan Kilborn
                  Maybe I should be explicit in this procedure since it is arguably a little less obvious than renaming in the Open dialog:
                  • Do File > Open
                  • Locate and click on file to backup (example test.txt)
                  • Press Ctrl+c
                  • Press Ctrl+v
                  Windows will create a new file (example: test.txt - Copy) – with the same timestamp as the original – and show it to you in the directory listing.
                  Rename THAT file as you like.
                  MM-JohnM 1 Reply Last reply Reply Quote 2
                  • mpheathM Offline
                    mpheath
                    The Open and Save Dialogs are blocking functions. All programs that call these functions will wait for the result to be returned. This is why you cannot interact with Notepad++ while the dialog is open, else you may get the not responding message if it were not disabled as Notepad++ is in a blocked state. This blocked state is probably causing the detection of the file state not to be done as Notepad++ is doing no processing at that time.
                    Modifying files while in these dialogs is what I would not recommend, as you have discovered with doing something unexpected during the task. This applies to any program that calls these dialog functions.
                      Alan Kilborn @mpheath
                      @mpheath said in one corner case where npp doesn't warn about "{file} doesn't exist anymore":
                      This is a good recommendation, although, in the end, Notepad++ really bears the responsibility to have a “smart” reaction when users do “dumb” things.
                      • MM-JohnM Offline
                        MM-John @Alan Kilborn
                        @alan-kilborn Copying a file (in windows) preserves its Date modified (LastWriteTime) but it changes its Date created (CreationTime).
                        Rename does not change the Date created (CreationTime).
                        Both operations, however, change the Date accessed (LastAccessTime)
                        This gif illustrates in windows explorer: https://postimg.cc/N54cMZSh
                          @mm-john
                          OK, not sure why you’re so particular about the timestamps (but you keep being you :-) ). I don’t really care to pursue further about that, as we’re moving into “off topic” land…
                          My diversion with the Ctrl+c/Ctrl+v thing was to point out how to create a copy of a file without changing its “modified” timestamp (the timestamp that means the most to ME). As noted, Save As and Save a Copy As both change this timestamp.
                          The relevant point was your main point in the first posting in this thread. I’ve recommended that you create an issue about that, so that’s all I’ve got.
                          • Pierre McGrailP Offline
                            Pierre McGrail
                            There is an option in MISC. that do exactly what I think OP needed. Just select ‘Enable for all opened files’ in ‘File Status Auto-detection’. Definitely what I need for case when file are also managed externally and sometimes gets renamed/deleted. My problem was hitting ‘save all’ in NP++ and all the files were rewritten on drive without giving me chance with the usual “Keep file in editor” dialog that we see when changing focus to this file.
                              Neil Schipper @Pierre McGrail
                              @Pierre-McGrail I was able to replicate OP’s issue with npp.8.4.9.portable.x64, so the option you mention, while very helpful in many situations, does not eliminate the problem.
