How to properly migrate/clone style settings from 1 PC to many others?
I do a lot of AutoHotkey work on Notepad++ and have many specific settings for the Styling. Even after copy/pasting the theme/styles folder, the new PCs don’t follow the same style as my original PC. is there a guide on how to do this properly?
Thank you.
AutoHotKey styling wouldn’t be in the themes folder or the active stylers.xml. Since AHK isn’t a built-in lexer, you would find it in the UDL definitions, so that means either the old
userDefineLang.xmlwhich has many UDL definitions in one file, or in theuserDefineLang\subfolder, which can have a separate file for every UDL.If you really want to copy all your settings from one PC to another, just copy the whole
%AppData%\Notepad++directory hierarchy. -
@peterjones said in How to properly migrate/clone style settings from 1 PC to many others?:
If you really want to copy all your settings from one PC to another, just copy the whole %AppData%\Notepad++ directory hierarchy.
I had considered this and was checking some of the XML (configuration) files within this folder structure. some of them contain path names unique to the resident PC. I wonder how NPP reacts when those pathnames are tried under a different environment that a different PC, likely with different user ID has? And then there is the “cloud” setting to consider.
As I see it, the developer has never intended on having a cloning mechanism created. So there isn’t a formal approach to cloning, this would be a bit of hit and miss with potential for some options to fail, unless the user was prepared to re-check all preferences etc after cloning.
@terry-r said in How to properly migrate/clone style settings from 1 PC to many others?:
I can vouch for the miss part of this. I’m attempting to “clone” the 32 bit ‘portable’ setup I use on my Win7 64 bit machine to a Win 8.1 tablet. Most everything seems to work most of the time, but there are enough intermittent issues that make me question the wisdom of a plain copy. Note: It does work well enough that I decided to jump to a Win10 Pro tablet with a decent sized screen as a ‘cloning’ target. My aging eyes couldn’t handle the too small screen on the Win8.1 mini-tablet.
To me, it sounds like Peter’s suggestion would work fine.
Can you elaborate on what paths you found?
@terry-r said,
I had considered this and was checking some of the XML (configuration) files within this folder structure. some of them contain path names unique to the resident PC.@Alan-Kilborn replied,
When I searched my Notepad++ config for path-looking lines, I saw:
session.xmlcontains the paths to the files in the current session. Those, of course, are machine-dependent. But Notepad++ will silently not open any file in the session that doesn’t existconfig.xmlcontains path names in the recent-file-list and in the search history (the find-in-files path field)shortcuts.xmlmay contain paths in the user-defined-commands; again, it won’t cause problems if they don’t exist (other than those commands won’t run when called)- some of the plugins config files may have paths
But since the OP wanted a clone of the settings, it doesn’t bother me to be replicating these paths, because cloning necessarily implies copying all the settings.
But I did realize that just copying
%AppData%\Notepad++may miss a couple settings: the “settings” that are controlled by the 0-byte files in the program-install folder, and the auto-completion config files in the program-install folder. So if those have been customized by @automatorMaxima , those will have to be copied to the new machine as well. -
Yea, what I was trying to get to the bottom of was: “Is there anything that Notepad++ itself needs that wouldn’t be copied over in your original technique?”
The items in your four bullet points would NOT be a concern for that. If users wanted those things to carryover for the first 3 bullet points, it is on them because it is “data”, not part of N++ that is needed. The point about plugins is “meh” because if plugin developers choose to hardcode paths, that’s their development choice, and well, the N++ devs and the support people can’t be expected to save them from themselves (nor account for that kind of stuff for all possible plugins when answering a question such as the OP’s).
But I did realize that just copying %AppData%\Notepad++ may miss a couple settings…
Good info. And another argument for using the portable version.
T Terry R referenced this topic on
