    Style Token text coloring issue
    7 Posts 4 Posters 987 Views
    • Tomáš KocourekT
      Tomáš Kocourek
      Hello,
      In previous versions it was possible to select whatever part of text and it colored it in whole file. But for some time I see it doesn’t work anymore.
      For instance, if I select this part of text as the Style Token and set color to it, nothing happens:
      Can you please fix it?
      Thanks
      Tomas
        Alan Kilborn @Tomáš Kocourek
        @Tomáš-Kocourek
        It works.
        Read the release note and/or the manual when you move to a newer version of Notepad++ than the one you are used to, because…THINGS CHANGE.
        Here’s a hint, though:
        @PeterJones FAQ this one?
        Tomáš KocourekT 1 Reply Last reply Reply Quote 1
        • Bas de ReuverB
          Bas de Reuver
          Which version of Notepad++ do you use? In your screenshot I only see the two “style token” menu items:
          Style token
          Remove style
          but when I right-click in a file, I see three menu items for the “style” part of the pop-up menu (btw I have Notepad++ v8.1.9)
          Style all occurrences of token
          Style one token
          Remove style
            PeterJones @Bas de Reuver
            @Bas-de-Reuver said in Style Token text coloring issue:
            It’s actually more complicated than “which version”, because if you started with a version before “style all” vs “style one” (specifically, before v8.0) then upgraded, your right-click context menu will not have upgraded, because Notepad++ installer/upgrader does not change config files that already exist in %AppData%\Notepad++, so it’s possible to have v8.1.9 without seeing the updated right-click menu.
            If you are in that mismatch situation, You can always download the portable zipfile of the same version as you have, and compare the contextMenu.xml from your installed copy to that from the portable, to see if there are any new commands available. Or, instead of that, you can look at the most recent contextMenu.xml on github.
            Bas de ReuverB 1 Reply Last reply Reply Quote 1
            • Bas de ReuverB
              Bas de Reuver @PeterJones
              @PeterJones ah ok, good point. Btw you could also just delete the %AppData%\Notepad++\contextMenu.xml file, and the next time Notepad++ starts it will just be re-downloaded automatically.
                Well, you could, if you hadn’t customized your right-click menu at all in your decade or more of using Notepad++. Since I have, I wouldn’t consider such a drastic solution. ;-)
                Technically, it would be re-created from the default settings in the executable; it doesn’t require an internet connection to re-create the default contextMenu.xml (or any other missing config file).
                • Tomáš KocourekT
                  Tomáš Kocourek @Alan Kilborn
                  @Alan-Kilborn said in Style Token text coloring issue:
                  @Tomáš-Kocourek
                  It works.
                  Thanks, this helped :-)
