    Regex help
    4 Posts 3 Posters 291 Views
    • Luis Piña IIIL
      Luis Piña III
      How can I put backticks around every line with words as well as end the lines with two spaces?
      On Reddit.com, using markdown, code must be between two backticks and lines can be separated by adding two spaces at of the end.
      • Neil SchipperN
        Neil Schipper
        Try:
        “. matches newline” unchecked
        find what: ^.*\w.*$
        replace with: \`$0\` <=== 2 spaces after 2nd backtick
          Alan Kilborn @Neil Schipper
          @Neil-Schipper
          Note that in this scenario, leaving the $ (end of line assertion) works just as well:
          find what: ^.*\w.*
            Alan Kilborn @Alan Kilborn
            @Alan-Kilborn said in Regex help:
            leaving the $
            Hmm, for maximum clarity I should have said:
            …leaving off the $ …
