    Notepad++ stuck in administrator mode [Solution]
    4 Posts 3 Posters 728 Views
    • Mainio MoosesM
      Mainio Mooses
      Stuck in Notpad++ wanting to get admin rights endlessly, drag & drop failures, context menu annoyance, broken flow? So, there’s a few discussions about this and the forum warned me of not reviving any old thread - hence the new thread.
      I had Notepad++ run as admin. Don’t go into registry or open up Powershell or cmd or something linuxy like that, it’s just a checkbox.
      • Right click on the executable or your shortcut to it
      • Select Properties -> Compatibility -tab
      • Uncheck the box next to “Run this program as an administrator”
      No more permanent admin mode :) Attached is an image from a finnish version running Win10 Home. Yeah I don’t like localization, either. But I gotta be versed in the finnish version as everyone uses it here in Finland. When giving tech support I must know what the client sees as exactly as possible.
      Bai!
        PeterJones @Mainio Mooses
        @Mainio-Mooses ,
        Thanks for sharing that.
        For those who cannot read Finnish:
        It should be noted that some of those previous threads also mentioned that setting, but it wasn’t always sufficient for some users’ situations.
        • mere-humanM
          mere-human
          Should we add this somewhere into the user’s manual?
            PeterJones @mere-human
            @mere-human said in Notepad++ stuck in administrator mode [Solution]:
            Interesting thought. Selecting Administrator mode or not, and whether your shortcut or executable have that selected, is really more of a Windows OS question, not a Notepad++ - specific question.
            But if you had a good idea where in the manual to put it, I wouldn’t immediately reject an issue to add that (especially if it came with an accompanying PR).
