    CTRL+H Help Me Please
    6 Posts 3 Posters 283 Views
    • ISMAIL ISMAILI
      ISMAIL ISMAIL
      hello friends
      I have thousands of fields in the HTML page like this. How can I do if you want to remove them completely?
      <span id=“text1”>
      <span id=“sample test” >
      <span id=“test page”>
      Sample
      <h3><span id="Joomla and Wordpress"><strong>8. What is the main difference between Joomla and WordPress?</strong></span></h3>
      The main difference between WordPress and Joomla was that Joomla started as a CMS to offer portal-like websites, while WordPress was a blog-oriented platform.
      <h3><span id="Wordpress Plugins"><strong>9. Is Joomla easy to use?</strong></span></h3>
      Joomla is easy only for developers. But at the same time, Joomla has a simple design these days. Thus, inexperienced users can use Joomla without extensive experimentation. Joomla is used by millions of developers to create powerful websites.
      <h3><span id="HelpMe"><strong>10. Is Joomla free to use?</strong></span></h3>
      Joomla is a free and open source content management system (CMS) developed to publish your web content.
      Thanks Ismail Oz
      ISMOZ.COM
        Alan Kilborn @ISMAIL ISMAIL
        @ISMAIL-ISMAIL
        Search for: (?-s)<span id=".*?">
        Replace with: nothing
        ISMAIL ISMAILI 1 Reply Last reply Reply Quote 4
        • Nuri UTKUN
          Nuri UTKU
          <span id=“(.*?)”> —> space
          </strong></span> —> </strong>
          • ISMAIL ISMAILI
            ISMAIL ISMAIL @Alan Kilborn
            @Alan-Kilborn Thanks a lot, I solved it. I’m so happy I’ve been dealing with it since morning
              Alan Kilborn @Nuri UTKU
              @Nuri-UTKU said in CTRL+H Help Me Please:
              @ISMAIL-ISMAIL
              Nuri-UTKU makes a good point about the closing </span> tag – if you are removing the opening tag, you probably want to remove the closing tag as well!
              As for my first reply, I try to just give people what they ask for.
              If they ask for the wrong thing, perhaps it helps them learn how to ask better questions. :-)
              • ISMAIL ISMAILI
                @Alan-Kilborn @Nuri-UTKU
                Thanks Nuri, I’ll take that into consideration.
