Control-Shift-S "save all file" repeats dialogue again and again
Whichever developer has handled that warning message on pressing Control-Shift-S to “save all file”, that developer is sufferring from Corona’s brother Morona, Which makes a person totally stupiditily idiotically Moron.
The dialogue repeats dialogue again and again, even after I confirmed dozens of times that yes, I had been using Control-Shift-S to save all opens files since ever, and I want the same behavior to continue.
So, let the developer get vaccinated by Anti-morona, so that his earlier mercurial brilliance returns.
All the best.
Thanks. -
So in all of your ranting and raving, you didn’t mention what version of N++ you are using. But one presumes 8.1.3 ?
I tried Ctrl+Shift+s using version 8.1.3, and it seems to work well.
However, again in all your ranting, you didn’t really present a strong steps-to-reproduce. So I don’t know exactly what you did and what you were expecting to have happen at any given step.
And of course you didn’t show your Debug Info, all leading to a lack of interest by most readers of your complaint, so probably no one’s going to do any more than I did (which was a quick test of the feature).
I think by the raving nature of your posting, you shot yourself in the foot with the goodwill of this forum (but of course you have a long history of doing odd things in your postings here, despite the change of username). So… who’s got the Moronavirus now?
@vsrawat ,
You might want to get your vision checked. In that dialog where you clicked “Yes”:
Do you see this time the text that says
Choose "Cancel" if your answer will always be "Yes" and you won't be asked this question again.? Follow those instructions. When you hit Cancel, it will complete the save, and you will never be asked again.Before insulting others, make sure you read the instructions.
It should be noted: I believe that choosing “Cancel” as the name of that third button was bad UI design.
The developer was probably choosing the quickest path to get that dialog working (since Yes/No/Cancel dialogs are built into Windows win32 API), but really, it would make a lot more sense to have the names of the buttons be Yes / Always Yes / No with a custom dialog.
Admittedly, you can just manually go to Settings > Preferences > MISC and uncheck
Enable SaveAll confirm dialog, but it would still be nice if the dialog were a bit more user friendly. -
Hmm, I had not seen this confirmation before.
IMO, maybe holding Shift down while pressing Yes makes more sense (and of course some prompt text to that effect).
If one hits Esc or presses theXin the upper right of the window (presumably to just-get-out, making nothing happen), doesn’t this also effectively set an “always-Yes” condition – I don’t think that would be desired…BTW, I hope by this continued discussion I am not giving any validation whatsoever to the OP’s initial rant of a complaint. :-(
Feel free to weigh in at #10339 – I am adding my 2c there.
There does seem to be a bit of karmic balance between the ‘not quite the greatest’ UIX setup of the dialog box and the OPs ranting behavior. Thanks to @PeterJones for the link to the ‘issue’ on github.
@Alan-Kilborn said in Control-Shift-S "save all file" repeats dialogue again and again:
8.1.3
No, I am on 8.1.2.
It is auto update checker that updates my npp. I don’t manually download and install it ever.
So, when version is not reported, you can take that to be the update channel updated latest version.
Thanks.
@PeterJones said in Control-Shift-S "save all file" repeats dialogue again and again:
@vsrawat ,
Choose "Cancel" if your answer will always be "Yes" and you won't be asked this question again.? Follow those instructions. When you hit Cancel, it will complete the save, and you will never be asked again.Well pointed. I was just hitting YES as that is my answer. I think I had read the entire thing first and then this is was I thought I am supposed to do.
Such a long message, non-moron developers should use less words. Warning are not story boards.
They should have given a separate tick box somewhere to say “don’t ask me again”, and then just Yes or No would have suffice. The above structure is very moronic and confusing.
Everything was working fine, and one day some developers unnecessary fiddles around and puts additional burden on users head to handle warnings and suggestions. That is sort of break down of a smoothly running thing. It should not be done, or should be done in a way that the user is not much disturbed by sudden new warning, with complex method to handle it.
You lack sense of humour, developers don’t, I have seen it previously. That was not an insult, that was leg pulling.
Thanks for your guidance and concern for morons.
yes, that is good step. Kudos to you for doing it in the proper way.
I provided some ideas with pictures in that GitHub issue. So feel free to provide your feedback or suggestions there.
I just wanted to flesh it out before doing something or asking for an opinion from the maintainer. -
@vsrawat said in Control-Shift-S "save all file" repeats dialogue again and again:
Normally I wouldn’t state it this way to a poster, but you started the “moron” thing. So here goes:
Only a moron would post something like: “when version is not reported, you can take that to be the update channel updated latest version”
I’m sure you don’t have the wisdom or thought-power to understand why, so I’ll tell you: If someone in 6 months is reading this thread to solve a problem, they’ll have no idea what version the discussion is related to. Heck, I’m reading it when it is very current and I got the version slightly wrong. If I had to think about the “update channel updated latest version”, I think it is just about impossible to figure out what that is at any given date/time, without some kind of map record of what that is/was.
Humor is fine if it is well-placed and well-timed. Your original posting in this thread was neither, so it wasn’t judged as humor. Why couldn’t you have just reported what you thought was a serious problem with the software, in a serious way?
At this point, I’m wondering which developer coded this dialog box this way, and why @donho approved it. It does NOT seem like something he would have accepted.
@Alan-Kilborn said,
It doesn’t take much wondering when commits are public: 80c285e
Right, and I had looked that up previously.
But the person (or at least their github name) who’s commit was accepted for this was unfamiliar to me, and isn’t a member of the official development team.So it was more of a rhetorical question of the form “Who the hell did that?!?” :-)
Update: After some thinking and discussing on GitHub, I’ve come up with the following idea.
The new version of Save All Confirmation dialog could look like this:
Yes to all - save all modified documents, show the Save As dialog for each of them.
Yes - save only the current document, show the Save As dialog for it, show the confirmation again for next documents.
No - don’t save the current document, don’t show Save As dialog for it, show the confirmation for next documents.
Cancel - stop the Save All process, don’t ask anything (same action as pressing the X button).
Do not ask again - checkbox that is wired up to the preference in MISC - Enable Save All confirm dialog.
Checking it, will check the preference. After that, the Save All Confirmation dialog won’t be shown until the preference is unchecked.
Also, there is a tooltip shown when hovering over the checkbox to give a user an additional hint.(Posting it here as well because I was asked to do so)
My 2c is that it feels awkward.
The question asked is “Save this and 3 other documents?”
(side note: if there is only one “dirty” document when Save All is invoked, hopefully it just saves it and doesn’t prompt)
If one answers “Yes” then I’d think that it is going to save 4 documents. So (pretending to be a dumb user), I don’t know the difference between “Yes to all” and “Yes”, given the wording of the question I’ve been asked.
If one answers “No” I’d think that nothing would be saved and I’m done. (But this is what “Cancel” or “X” does).
“Do not ask again” maybe doesn’t imply well that the choice chosen here will be remembered?
If this is a “Save All Confirmation”, why is this ultra-complicated?
Can’t the prompt be “Are you sure you want to save all?” and have two buttons “Yes” and “No”.“Yes” would allow the save-all to proceed (as usual in prior N++ versions). “No” or “X” would just cancel.
And don’t bother with the “Do not ask again”. User can go to the Preferences to change that if they want.
I suppose it is possible to “fix” this, and keep the spirit of the recent change…but it may not be “easy”.
Good luck and thank you for trying.
And BTW…
Don’t we already have something similar for “Close All” variants?
For example, if I have multiple dirty documents and I do a close-all, I get:
If something similar is to be kept for the “Save All Confirmation”, shouldn’t the button ordering and captioning be consistent across the application (i.e., in both places)?
Also, it might be nice if the “Save” dialog I show could identify “…and 3 other documents” like the proposed “Save All Confirmation”…
This is a tough one. Despite the use case and the dialog looks simple, it’s hard to come up with a good solution.
I was also thinking about reusing this dialog.
After your latest comments, I think this would be a good alternative to the current version of the dialog.The only thing here is that it seems “No to all” is actually the same as “Cancel” or the X button.
As it was said by @PeterJones :Personally, with a Save All dialog, I don’t understand the need for a “No to All” that’s separate from “Cancel”, because they both mean, “no, I didn’t actually mean to Save All”.
Sure. I just came up with this as a slight improvement, a shortcut if you want.
Because, in the current version, the “Cancel” button seems to modify a preference:
I personally don’t like that the “Cancel” button now works conter-intuitive and I need to read the explanation in the dialog to understand it.So I wanted to keep that in some form, but make it more obvious.
Anoter much simpler idea I had: Keep only Yes/No buttons but add that checkbox instead of Cancel (in current version) + explanation in the tooltip.
Because, probably the same dialog as in “Close All” case would be better for consistence. -
What about a hybrid between @Alan-Kilborn & @mere-human earlier selection?
(please excuse the ugly
artworkexample:
additions/changes/tweaks:
“new 9” updates to the next file for each single press of ‘Yes’ or ‘No’
‘Yes’ saves the file in question, ‘No’ doesn’t and both skip to the next file
‘N’ counts down as Yes or No are pressed
add a balloon hint to ‘Yes to all’ to show the ‘Can be changed in preferences’ hint.The part I’m not sure about is: What to do when the list of N+1 files has been presented and there are still unsaved files. My first thought is that’s the job of the ‘Close’ dialog as the ‘Save All’ dialog has completed it’s job. My second thought is to ask for ideas.
BTW: I’d rather see ‘Yes to all’ be rewritten as ‘Yes, save all’
