    Integration of a script writen in Python
    27 Posts 4 Posters 7.6k Views
    • tho-gruT
      tho-gru
      Thanks for your additions.
      I already used the startup (user) script.
      Kind Regards,
      Thomas
      • tho-gruT
        tho-gru
        I opened the issue 205 for the difference in “preloaded” modules.
          Alan Kilborn @tho-gru
          @tho-gru
          I think the reason for the “difference” was explained HERE, so you may want to withdraw your issue.
            PeterJones @tho-gru
            @tho-gru ,
            To use different words than @Alan-Kilborn and @Ekopalypse have already used to try to explain this to you:
            As was explained to you above by @Ekopalypse (in case @Alan-Kilborn’s link doesn’t work well – links to individual posts in the NodeBB-based forum don’t highlight the post, and sometimes don’t scroll to the part of the post you expect them to – you can look in this topic for where @Ekopalypse said, “because it is then defined in the main namespace”) before you created the issue 205, when you run a script from the PythonScript Scripts menu, it is in the __main__ namespace, so if your startup.py has already imported those default symbols, then the names are already defined in that __main__ namespace, and so are available to your script. However, when you have a line in startup.py that imports your script (the import TgrUrlAltClick), Python (not the PythonScript plugin) puts that whole file in its own namespace (TgrUrlAltClick, in your example). Thus, in the context of that imported script, the TgrUrlAltClick namespace has never imported the symbols from the Npp module, and that is why the Npp-defined objects notepad, console, and editor are not available to functions in your imported script.
            The PythonScript plugin cannot and will not redefine the Python language import mechanism to inject the __main__ namespace symbols into whatever scripts you happen to import via startup.py.
            The PythonScript plugin cannot and will not do any magic in startup.py that will be able to recognize when an import in startup.py is really trying to auto-execute a user-defined script rather than importing a standard Python library, so cannot and will not try to magically inject the __main__ namespace symbols into the scripts you happen to import via startup.py.
            You can and should and are expected to import the symbols that you need from the Npp module into any script that you desire to import from startup.py or from any other script, because that is the only way to guarantee that any script you write will have access to those symbols whether the script is run from the PythonScript Scripts menu or by being imported as a module from another script. Adding the line from Npp import * (or a reduced version if you don’t need all the Npp symbols) into all your scripts is not an onerous task on your part, and importing modules and symbols is an expected aspect of any Python development, not just PythonScript development.
            (A copy of this has also been posted in your issue)
            • tho-gruT
              tho-gru
              @PeterJones I fully understand that I need to import symbols from other modules by typing import ....
              Unfortunately (now I understand why) I did not get an error message while executing the script via the menu. My complain is not the need of importing modules I am using in my script. My complain is that I want to get same error messages independent how I can start a python script.
              I currently see two possible solutions to achieve this:
              1. hide (unload or what ever possible) the console module for scripts started via the menu
              2. “preload” the console module to be available for all script started via the startup.py (user or system)
                Of course the should be done for all “preloaded” modules available in scripts started via the menu.
              This should simply remind beginners to import the modules needed.
              Kind Regards
              Thomas
                PeterJones @tho-gru
                @tho-gru said in Integration of a script writen in Python:
                Not fully, because your option 2 below seemed to indicate you still think it’s possible to pre-load it.
                Then change the from Npp import * from the machine and user startup.py to import Npp yourself. That way, the errors will come from the beginning for you, without influencing other people who do not want to have to do the imports when using the PythonScript console in immediate mode. (If you do this, calls to the standard objects inside the startup.py scripts will have to be prepended with Npp.)
                1. “preload” the console module to be available for all script started via the startup.py (user or system)
                As already explained in detail above, but I’ll try to phrase it differently, because you have not understood, despite saying that you understand: The startup.py currently preload the Npp instance variables into the __main__ namespace, and thus for every script started from the menu, those constants are pre-loaded. But that cannot affect scripts that you import into your startup.py script, because that’s not the way Python import works – when you import a module in a given, it imports into the current namespace seen by that file; startup.py are in the __main__ namespace, so they import symbols into the __main__ namespace; scripts run from the menu are in the __main__ namespace, so they import symbols into the __main__ namespace; but a script like TgrUrlAltClick.py that is imported into some other script (like using import TgrUrlAltClick in starup.py to import a script rather than a standard module) is in its own namespace, so none of the functions defined inside TgrUrlAltClick.py will see the __main__ namespace symbols because functions inside TgrUrlAltClick.py are in the TgrUrlAltClick namespace in this condition.
                What you are asking in point#2 is the equivalent of saying that when you have the following situation, it should work instead of throwing a NameError exception.
                C:\usr\local\apps\python-3.9.6-embed-amd64>type mainFile.py
                #!python
                # encoding=utf-8
                from sys import path
                from MyOtherScript import myFunction
                myFunction()
                C:\usr\local\apps\python-3.9.6-embed-amd64>type MyOtherScript.py
                #!python
                # encoding=utf-8
                print("Hello from namespace '{}'!\n".format(globals()['__name__']))
                def myFunction():
                    print(path)
                C:\usr\local\apps\python-3.9.6-embed-amd64>python mainFile.py
                Hello from namespace 'MyOtherScript'!
                Traceback (most recent call last):
                  File "C:\usr\local\apps\python-3.9.6-embed-amd64\mainFile.py", line 6, in <module>
                    myFunction()
                  File "C:\usr\local\apps\python-3.9.6-embed-amd64\MyOtherScript.py", line 7, in myFunction
                    print(path)
                NameError: name 'path' is not defined
                Beginners don’t import their scripts into startup.py; beginners run their scripts manually from the menu. People who want to do more advanced actions, like automatically running their script from startup.py by importing the script via a command in startup.py need to learn about things like namespaces and importing, and need to actually understand those concepts … or at least be willing to take the advice to “always from Npp import * in every script if you’re going to do anything but run your script from the menu”.
                  @PeterJones said in Integration of a script writen in Python:
                  Also, people who want to do more advanced actions read the manual that’s included with PythonScript plugin, which says quite explicitly in the Npp Module section of the Introduction:
                  Honestly, beginners, not just people moving on to advanced topics, should have also at least read the whole introduction.
                  The manual was quite explicit: if you want to write a module (a new file) that is called from someplace else (which is exactly what you do when you import your script into startup.py), then you need to include the from Npp import * inside your module.
                  We’ve told you. The manual has told you. Good luck.
