    Multi-line selection doesn't work when i try to do it while my screen is being shared via WebEx. Anyone else noticed this problem ?
    2 Posts 2 Posters 172 Views
    • arulanandA
      arulanand
      Multi-line selection doesn’t work when i try to do it while my screen is being shared via WebEx. Anyone else noticed this problem ?
        PeterJones @arulanand
        @arulanand ,
        I don’t use WebEx anymore (it’s been a few years), so I’ve never seen that issue. However, sometimes screen sharing and remote controlling software of that type will highjack one of the Ctrl and/or Alt keys for its own internal use. You might be able to use right-Ctrl vs left-Ctrl or right-Alt vs left-Alt for making sure that Notepad++ sees the modifier key instead of WebEx highjacking it.
