    split line help requested
    splitnewline
    4 Posts 3 Posters 256 Views
    • Matt WhitlockM
      Matt Whitlock
      recipes.addShaped("aetherworks:prism", <aetherwork
      recipes.addShaped("aetherworks:prism_support", ul
      recipes.addShaped("animania:banner",
      recipes.addShaped("animania:banner_alt"
      recipes.addShaped("aquaculture:iron_fishing_rod",
      I am sure this will be really easy for someone, but I have searched google for 20 minutes without any luck.
      I just want to add a new blank line after every time the first word after the first quote mark changes from the above, to this:
      thanks
        PeterJones @Matt Whitlock
        @Matt-Whitlock ,
        Not “really easy” for me, though I was able to figure it out; it just took some time. (There are others here who are better at regex than I am; I was hoping one of them would step in, but since they hadn’t yet, I thought I’d put a few minutes in now that I found a little bit of time.)
        • FIND = (?x-s) \(" (\w+) .*\R\K(?= .*? \(" (?!(\1)) \w+ )
        • REPLACE = \r\n$0
        • Search Mode = regular expression
        “Quick” Explanation:
        • (?x-s) = allow extra spaces in the regex for easier readability; make sure . doesn’t match newline
        • \(" = Match a literal ( and a literal "
        • (\w+) = grab a word and put it in memory as group#1
        • .*\R = eat up the rest of the line, including its EOL sequence
        • \K = reset the match, so the replacement won’t try to delete/change that first line
        • (?= ...) = this is a lookahead assertion, so what’s in here has to match, but again won’t be part of the full match
        • .*? = this gobbles up the first part of the new line
        • \(" = match a literal ( and a literal " on the second line as well
        • (?! ... ) = a negative lookahead, which says whatever comes next cannot match what’s inside
          • (\1) = this matches the same value as what was in group 1
          • since it’s in the negative lookahead, that means that this will only be true if what comes next does not match what’s in group#1
        • \w+ = this is the word (which because of the negative lookahead must be a different word that the value of group#1)
        After those are all combined, the actual match is actually just the 0-width position at the beginning of each line whose word doesn’t match the previous line’s word.
        It is replaced by a \r\n, which is the windows CRLF newline sequence; if you are using linux EOL, just use \n there.
        I added a couple of extra test cases based on your description, because I wanted to make sure that it properly handled words who were only on one line.
        original data:
        recipes.addShaped("aardvark:animal", blah
        recipes.addShaped("abcdefgh:alphabet", blah
        transformed:
        (My first implementation didn’t have the lookahead on the second half, which meant it consumed that line without grabbing its word, and thus it didn’t put a blank line between abcdefgh and the first aetherworks. I was glad I had added the two single-line words, otherwise I wouldn’t have seen that bug.)
        You did a good job presenting before and after data, so kudos for that. But I’ll present my normal hints for getting regex help, since there are helpful links. And some of the advice may also help you with asking an even better question next time. (“… If there is a next time.”)
          Hello @matt-whitlock, @peterjones and All,
          An other solution, based on the same idea than @peterjones, with a positive look-ahead, containing itself a negative look-ahead searching for a key-word different from the previous one !
          SEARCH (?-si)^.+?"(.+):.+\R\K(?=[^"\r\n]+"(?!\1:))
          REPLACE \r\n
          Tick the Wrap around option and click on the Replace All button only ( Do not use the Replace button )
          I assume that there is only one : character per line, right after the KEY-WORD to look at !
          BTW, Peter no need to add $0, in the replacement part, as it represents an empty string, in that specific case ;-))
          Best Regards
          • Matt WhitlockM
            Matt Whitlock
            Thank you for the replies friends. <3
