    Panel layout corruption after power loss
    panelcorrupted
    3 Posts 2 Posters 809 Views
    • Ron PrestenbackR
      Ron Prestenback
      Hi there,
      I’m having an issue with Notepad++ after a power loss. I’ve searched the forums but didn’t find any posts describing this problem. If there is one, please direct me to it.
      My PC lost power yesterday while Notepad++ was open. After restarting the PC and relaunching Notepad++, the layout looks like the following screenshot. If I click the X button on those “ghost” panels, the layout corrects itself, but it’s back to this after I restart Notepad++:
      I assume the power loss corrupted one of Notepad++'s configuration settings, so I tried clearing the locations I know about…is there one I missed?
      • I’ve tried clearing the %APPDATA%/Roaming/Notepad++ directory (while notepad++ was closed, of course), but there was no difference.
      • I also tried downgrading to a previous version of notepad++ (I’d just installed the latest version before the power loss), but that made no difference.
      • Finally I checked Windows registry under SOFTWARE\Notepad++ in both the HKLM and HKCU hives. That key only exists in HKCU, but the only value it has is the default value containing the installation folder for Notepad++)
      Are there any other settings locations I should check and clear?
        PeterJones @Ron Prestenback
        @Ron-Prestenback ,
        Known problem with no known solution, though for some, rebooting or updating video drivers has helped. For others, they had to roll back a recent windows update (but some say that they don’t have that update and still have the problem). At least one user has confirmed it’s not just Notepad++ but other applications (including some Microsoft apps), which implies that it’s not solely related to Notepad++.
        See also:
        • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/9717
        • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/9760
        • https://community.notepad-plus-plus.org/topic/21128/disintegrated-ui
        • https://community.notepad-plus-plus.org/post/64735
        • https://community.notepad-plus-plus.org/post/65188
        Ron PrestenbackR 1 Reply Last reply Reply Quote 1
        • Ron PrestenbackR
          Ron Prestenback @PeterJones
          @PeterJones OK, thanks - I’ll follow up in one of those threads.
