    Help to arrange text??
    3 Posts 2 Posters 259 Views
    • ParkourfingerP
      Parkourfinger
      Hi guys my problem may seems dumb but i was playing with notepad++ for 2 days and still cant seems to find how to do it :(
      So my question is that i have a set of data arranged in raw text like this :
      Work:Carpenter
      and Because i have lots of data and for efficient time i would like fo it to be output like :
      Mourat|65|Carpenter
      Like all info in the same line separated by a | if you know how to do it please let me know would be glady appreciate :)
        Hello, @parkourfinger and All,
        • If each record consists of 3 consecutive fields only, use this regex S/R :
        SEARCH : (?-s)^.+:(.+)\R.+:(.+)\R.+:(.+)
        REPLACE \1|\2|\3
        • If each record consists of several consecutive fields, use the generic regex S/R :
        SEARCH (?-is)(?:(Title of the Last Field)|.+)Value Separator(.+)\R?
        REPLACE \2?1\r\n:Field Separator
        In this present example as :
        • The Title of the Last Field is the word Work
        • The Value Separator is the : punctuation sign
        • The Field Separator is the | symbol
        Hence the following regex S/R :
        SEARCH (?-is)(?:(Work)|.+):(.+)\R?
        REPLACE \2?1\r\n:|
        As usual, select the Regular expression search mode and tick, preferably, the Wrap around option !
        ParkourfingerP 1 Reply Last reply Reply Quote 1
        • ParkourfingerP
          Parkourfinger @guy038
          @guy038 Thank you very much it worked!
