    Finding characters and using them to replace
    3 Posts 2 Posters 290 Views
    • A
      Acme1235
      Hey all,
      Is there a method to use find and replace to grab a part of code from a line and use it in the replacement?
      For example, I have a line of code that has docname=“******.svg” for multiple documents. I want to take the ****** and use it in a new line with the following statement. <title ******</title>
      I understand that you can use regex to create your new line /n and .* for characters, but is there anyway to grab characters from a string and use them in your replacement?
      Thanks for the help!
        PeterJones @Acme1235
        @Acme1235 ,
        Yes, use regular expression mode, and a feature known as capture groups where you use a pair of () around the text that you want to match and ${1} in the replacement to reference the first group. With a couple other features, described below, I think I have what you want.
        For example,
        • FIND WHAT = (?-s)docname="(.*?)\.svg".*(\R)
          • (?-s) turns off “. matches newline”, so that a filename won’t accidentally span multiple lines with a newline sequence inside
          • there is some literal text, and the file name (sans .svg) ends up in group #1
          • then allow any text to the end of the line
          • and save the EOL character in group #2
        • REPLACE WITH = ${0}<title>${1}</title>${2}
          • ${0} is a special case of the group# replacement, where group#0 is the whole matched string
          • <title>${1}</title> gives the name of the file as the content of the title
          • ${2} takes the EOL character(s) from group#2 and uses them to end the new <title> line. (I could have just used \r\n if I wanted to assume you use Windows CRLF line endings, but this forum has shown that’s a bad assumption to make)
        • SEARCH MODE = regular expression
        • you can hit REPLACE multiple times, or REPLACE ALL once
        If this works, great! If not, try studying the documentation that was linked above, and things in the boilerplate below, try to modify this regular expression yourself to meet your needs, and feel free to come back with specific questions if you have problems. You will only learn by trying.
        A 1 Reply Last reply Reply Quote 1
        • A
          Acme1235 @PeterJones
          @PeterJones thanks so much for the help and links! I’ll be using it a good bit in the upcoming weeks so I’ll definitely read up on it!
          Happy friday!
