    Help with FIND
    6 Posts 2 Posters 402 Views
    • Antonio RoscianoA
      Antonio Rosciano
      Hi everybody,
      Which is the shortcut to close the window of FIND RESULTS?
      I’ve been looking for it for a long time …
      Thank you.
      • Antonio RoscianoA
        Antonio Rosciano
        Come on …
        “A simple question deserves a simple answer …”
        Thanks to whoever comes forward.
          Hello, @antonio-rosciano, and All,
          Since the v7.9.1 release of Notepad++ :
          • If focus is on the Search Result panel, simply hit the Esc key
          • If focus is on the editor window, hit the F7 key, first, to move focus on the Search Result panel. Then, hit the Esc key !
          • Antonio RoscianoA
            Antonio Rosciano
            Tanks guy038.
            Didn’t work…
            I presume I know why, in your post you refer to version 7.9.1. I have 7.9 (32 bits).
            Thanks anyway
            • Antonio RoscianoA
              Antonio Rosciano
              Hi,
              I moved to v7.9.1 and it did it!
              Thanks for your time.
                Hi, @antonio-rosciano and All,
                However, note that the latest version of N++, as of February 26, 2021, is version 7.9.3 ! !
