    Notepad ++ place switching
    3 Posts 2 Posters 307 Views
    • Ilyassb02I
      Ilyassb02
      Hello im Trying to set custom aliases for a plugin and i encountered this problem:
      i have a custom_aliases.yml file im working on and it goes like this
      BOOKSHELF: Bookshelf
      HAY_BLOCK: HayBale
      HONEY_BLOCK: HoneyBlock
      MAGMA_BLOCK: MagmaBlock
      etc…
      but i want it the other way around like:
      Bookshelf: BOOKSHELF
      HayBale: HAY_BLOCK
      etc…
      doing them manually will take ages since i have about 7000 lines
      i tried to use the search and replace feature but no luck so far
        Hello, @ilyassb02 and All,
        Child’s play with regular expressions !
        • Open your file in N++
          • SEARCH (?-s)^(.+)(:\x20)(.+)
          • REPLACE \3\2\1
          • If necessary, tick the Wrap around option
          • Click on the Replace all button
        Et voilà !
        Notes :
        • We separate the line contents in three groups, with the “colon + space” chars as a pseudo-delimiter
        • In replacement, we rewrite the last part of lines, then the colon + space delimiter and, finally, the first part of lines
        Best regards
        Ilyassb02I 1 Reply Last reply Reply Quote 2
        • Ilyassb02I
          Ilyassb02 @guy038
          @guy038 thank you man. worked like a charm
