    Bug or problem with block comment in another block comment
    2 Posts 2 Posters 749 Views
    • AndreyA
      Andrey
      Hi All
      i found some problem with block comment.
      So.
      {} blok comment
      add block comment
      its fine
      but if a add another block comment over exist.
      do not worked.
      if block comment include another block comment. it is not working.
      Sorry for may english.
        PeterJones @Andrey
        @Andrey ,
        What language lexer has block comments like that? Or are you using a UDL?
        And does that language actually allow nested comments? Some languages do, some don’t, and some leave it up to a compiler implementation decision.
        If the language really allows it, but the built-in lexer allows it, then technically, that’s a bug in the lexer. However, the lexers that ship with Notepad++ are part of the Scintilla code library that Notepad++ uses, so it would be a long, unlikely process to get it fixed (report the bug to Scintilla; wait for it to maybe get fixed; request Notepad++ update its Scintilla; wait for likely many years before Notepad++ does update its Scintilla, if ever)
        If you are using a UDL, that lexer uses a very simple algorithm, which was not built to handle nested comments (and even if you submitted an issue on it, the UDL lexer, even though technically controlled by Notepad++ unlike the other lexers, hasn’t had any significant improvements in years)
        You can add extra highlighting to a builtin lexer or to a User Defined Language (UDL) using regexes via the script EnhanceAnyLexer.py that @Ekopalypse shares in his github repo, but you might have to tweak his code to be able to handle nested comments.
        My general coding practice on nested comments: don’t.
