    Regex replacement not working
    2 Posts 2 Posters 415 Views
    • Paul MoloneyP
      Paul Moloney
      I’ve checked the following regex string against a number of regex syntax checkers and it’s valid:
      <img src="([A-Za-z0-9-_\.%]*)" alt="([A-Za-z0-9-_\.]*)"(\s)*\/>
      (I’ve also tried the alternative where the double-quotes are escaped:
      <img src=\"([A-Za-z0-9-_\.%]*)\" alt=\"([A-Za-z0-9-_\.]*)\"(\s)*\/>
      However, neither of these work for me in Notepad++ regex:
      Any help on the valid syntax for Notepad++ appreciated (what flavour of regex does it use?
      P.
        PeterJones @Paul Moloney
        @Paul-Moloney said in Regex replacement not working:
        The docs explain Notepad++ uses the Boost regular expression library (v1.70).
        But in every regex version I’ve used, [A-Za-z0-9-_\.%] would cause problems; in general, hyphens mean “range” inside a character class, unless they are escaped or the last character in the class. So [0-9-] is okay, [0-9-_] is not, but [0-9_-] is (non-range hyphen last) and [0-9\-_] is.
