    Python plugin works in NPP 7.7 but does work in NPP 7.8 upward
    24 Posts 2 Posters 1.9k Views
    • Stier HahnS
      Stier Hahn @Ekopalypse
      @Ekopalypse you are doing great job , thank you !
      ps
      I came across a next roadblock , that’s more a pywin32 issue.
      See https://github.com/mhammond/pywin32/issues/1658
      May be you would have a hint how to troubleshoot that. as that seems to be sort of related to dependency lookup process.
      In a nutshell I’ve NPP plugin linked against boost::python which loads at startup some initialization python code. And it’s was working fine under py 3.7 and npp 7.7.
      Finally ( with your help) I managed to upgrade npp from 7.7 to 7.9
      and partially from winpython 3.7 to winpython 3.8.
      My NPP python plugin is loaded at startup, but execution of initialsation python scripts fails to import win32api.
      Embedded python wrapper is working fine ( I guess ) as import os / import sys and other simple code is working inside my plugin.
      I’m using win py 3.8 and latest pywin32 ( 300)
      Stier HahnS 1 Reply Last reply Reply Quote 0
      • Stier HahnS
        Stier Hahn @Stier Hahn
        @Stier-Hahn pywin32 is installed sort of correctly as it works from python command line.
          Ekopalypse @Stier Hahn
          @Stier-Hahn
          there is an additional
          ...\AppData\Roaming\Python\Python38\site-packages
          path when used by the command line.
          Maybe give it a try to add it to your sys.path from embedded python.
          Do you know procmon?
          It could be used to see what npp and your plugin tries to load with a filter set to path contains whatever
          If importing pywin32 failed with unable to load dll
          then one of those
          can not be found I guess.
          python38 shouldn’t be the problem but pywintypes38.dll might be in this additional path I’ve mentioned earlier??
          Stier HahnS 1 Reply Last reply Reply Quote 2
          • Stier HahnS
            @Ekopalypse cool, thanks for advice, turned out to be pywin32_system32 not being searched for some reason
            Apparently lookup path was (intentionally screwed up) modified
            I managed to fix my problem by placing pywintypes38.dll and pythoncom38.dll to NPP root
