    Replace string between quotes
    3 Posts 2 Posters 711 Views
    • Savvas KechagiasS
      Savvas Kechagias
      Hello npp community!
      So, i searched the forum but was unable to find something that suits my needs.
      Lets say I have a file with many strings like:
      "str1"
      "str2"
      "str100"
      I want to add something before and after the quotation, but keep the content of the string, not sure if this is clear!
      Example :
      I want the above to be like
      xor("str1").crypt()
      xor("str2").crypt()
      xor("str100").crypt()
      Is that possible?
      • astrosofistaA
        astrosofista @Savvas Kechagias
        Hi @Savvas-Kechagias
        Yes, it is possible. The following regex does what you want given the data you provided:
        Open the Replace dialog (Ctrl + H) and type in:
        Search: ^("[^"]+")$
        Replace: xor\($1\).crypt\(\)
        Check the Wrap around option
        Select the Regular expression search mode
        Click on the Replace All button
        Have fun!
        • Savvas KechagiasS
          Savvas Kechagias
          Oh thanks! Seems like I have to study some RegEx :)
          Appreciate your answer!
