    Help about text find and replace
    3 Posts 2 Posters 282 Views
    • Matteo SalviatoM
      Matteo Salviato
      Hi Guys,
      My name is Matteo nd , if is possible I need your help !!
      I need to change all the lines like this “txt”: “AGUAAAA”, with this thext “txt”: “”,. the word Aguaaaa could be different for every line… could you help me?
      thanks in advance
        Hello @matteo-salviato and All,
        Very easy with regular expressions !
        I supposed that your text contents usual double quotes " and not the Unicode chars “ and ” !
        Then :
        • SEARCH (?-si)"txt":\x20"(.+?)"
        • REPLACE "txt":\x20""
        • Tick the Wrap around option, preferably
        • Matteo SalviatoM
          Matteo Salviato
          @guy038 said in Help about text find and replace:
          Open the Replace dialog ( Ctrl + H )
          SEARCH (?-si)“txt”:\x20"(.+?)"
          REPLACE “txt”:\x20""
          Select the Regular expression search mode
          Click on the Replace All button
          Thanks a lot!!! it works very well!!!
