    Need help for regular expression - find, insert and delete
    11 Posts 3 Posters 3.8k Views
      Alan Kilborn @Venus642
      @Venus642
      Perhaps this is a correct clarification:
      • If a | character is not found after the leading digits on a line, insert it with a space before it and a space after it
      • If a | character is found anywhere else in a line, remove it and anything that follows it (and any space before it)
      • Venus642V
        Venus642
        Thanks Alan for your Info and help.
        How can I change that with regex?
        220 Txt Txt Txt
        To:
        220 | Txt Txt Txt
        Or delete and insert:
        10 Txt Txt Txt | 300
        To:
        10 | Txt Txt Txt
        Sorry. I have no idea how to make regex do it…
        Alan KilbornA astrosofistaA 2 Replies Last reply Reply Quote 0
          @Venus642
          I would do two separate steps:
          find: ^(\d+ )([^|])
          repl: ${1}| ${2}
          and then:
          find: (?-s)^(\d+ \|.*?) \|.*
          repl: ${1}
          Venus642V 1 Reply Last reply Reply Quote 3
          • Venus642V
            Venus642 @Alan Kilborn
            WooooooooW!
            Alan -Big big thanks for your help!
              @Venus642 said in Need help for regular expression - find, insert and delete:
              Pay back by learning about how it worked, so that next time you don’t have to ask. :-)
              Start with information HERE
              • astrosofistaA
                astrosofista @Venus642
                Hi @Venus642, @Alan-Kilborn
                Another option, in one step:
                Search: (?-s)(?:^(\d+) *?([A-Za-z]+))|( *?\| *?\d+)$
                Replace: ?1($1 | $2)
                Have fun!
                Venus642V 1 Reply Last reply Reply Quote 1
                • Venus642V
                  Venus642 @astrosofista
                  One step - Perfect…
                  Alan and astrosofist - Top help!
                    One step - Perfect…
                    Yea, I wouldn’t get too bogged down in it needing to be a one-step operation.
                    If it is something you need to do often, you will make it a macro anyway (so you can give it a meaningful name).
                    And if it is a macro, it can just as well be two replacement steps (because, by the nature of macros, multiple steps look like one step).
                    Venus642V 1 Reply Last reply Reply Quote 0
                    • Venus642V
                      Alan I have tested again and your solutions is better in my case.
                        Alan … your solutions is better
                        Well, I certainly wasn’t trying to “win”. :-)
                        I often try to point out that a solution to such a problem doesn’t have to be all crammed into one operation.
                        It can make the operation harder to understand for a novice with regular expressions.
