    Add comma between two sentences on a two language document
    7 Posts 4 Posters 538 Views
    • Ali JafariA
      Ali Jafari
      Does anybody know how can we input a comma at the endpoint of a line, when we are working in a two language document?, suppose we have a sentence like this “this is a testاین یک آزمایش است” in this sentence I have an English text and a Persian text at the end, now I would like to have this sentence like this"this is a test,این یک آزمایش است", actually I would like to do this in a large document with “Search and Replace” command.
        Terry R
          Ekopalypse @Ali Jafari
            Hello, @ali-jafari, @terry-r, @ekopalypse and All,
            As you may know, the different Arabic characters belong to one of these 5 Unicode blocks :
            • Arabic : [\x{0600}-\x{06FF}]
            • Arabic Supplement : [\x{0750}-\x{07FF}]
            • Arabic Extended-A : [\x{08A0}-\x{08FF}]
            • Arabic Presentation Forms-A : [\x{FB50}-\x{FDFF}]
            • Arabic Presentation Forms-B : [\x{FE70}-\x{FEFF}]
            Refer to :
            http://www.unicode.org/charts/PDF/U0600.pdf
            http://www.unicode.org/charts/PDF/U0750.pdf
            http://www.unicode.org/charts/PDF/U08A0.pdf
            http://www.unicode.org/charts/PDF/UFB50.pdf
            http://www.unicode.org/charts/PDF/UFE70.pdf
            So, here is the road map :
            • SEARCH ([\x{0021}-\x{007E}])\x20?(?=[\x{0600}-\x{06FF}\x{0750}-\x{07FF}\x{08A0}-\x{08FF}\x{FB50}-\x{FDFF}\x{FE70}-\x{FEFF}])
            • REPLACE \1,
            • Tick the Wrap around option
            Notes :
            • The part ([\x{0021}-\x{007E}]) searches for any single ASCII character from \x{0021} = ! till \x{007E} = ~, stored as group 1, due to parentheses, possibly followed by a space char ( \x20? ) ONLY IF  followed with an arabic char, from one of the five zones described above ( due to the lookahead construction )
            • In replacement, the English-American char is simply rewritten ( \1 ) with a comma
            For instance the two lines :
            this is a test این یک آزمایش است
            would be changed as :
            P.S. :
            Note that the sub-regex which matches the English-American character is [\x{0021}-\x{007E}] and not [\x{0020}-\x{007E}] ! Indeed, as the Arabic text contains, itself, spaces chars too, we would have some false positive matchs among the Arabic text ;-))
            • Ali JafariA
              Ali Jafari
              @guy038 said in Add comma between two sentences on a two language document:
              \1,
              Dear friend,
              Thanks for your great support, I have tried and it answered.
              All the Best.
              • Ali JafariA
                Ali Jafari
                \1,
                Dear my friend,
                Could you please tell me is this way OK for Microsoft office Word or not?, or I need to do something else ?.
                All the Best.
                  Hi, @ali-jafari and All,
                  Unfortunately, I cannot give you valuable information :-(( I’m presently using, on my old XP laptop, the Microsoft Office Suite … 2002, which is good enough for my Word’s work !
                  SEARCH ( for Word ) : ([^0033-^0126])^0032*([^1536-^1791])
                  REPLACE ( for Word ) : \1,\2
                  In Word 2002, when your tick the search option Use generic characters, any non-Unicode char ( below \x0100 ), must be written as ^####, where #### represents the decimal value of the code-point. So, \x{0021} must be changed as ^0033, \x{007E} as ^0126 and so on…
                  Unfortunately, syntaxes over \xFF, as for the main Arabic range [^1536-^1791], that is to say {\x{0600}-{06FF}] in N++ ), is definitively not a valid syntax :-((
                  Moreover, the quantifier syntax {0,n}, after a possible space char, does not work, too. The {1,n}, only, seems valid ! So I prefered to use the usual * syntax
                  Certainly, the recent versions of Word allows the search of characters of the BMP ( so from \x{0000} to \x{FFFF} ). If so, the proposed regex S/R should work correctly !
                  On the other hand, why not process with the N++ regex engine, first and, then, paste your updated text in Word ?
