    Problem with basic search
    6 Posts 5 Posters 384 Views
    • Keith LengK
      Keith Leng
      I must be doing something wrong, but I’m not sure what. Often, when I search for a term, no results are returned, despite that the term is present in the document. It seems to be something to do with having multiple tabs open. If I search in all opened documents, it will find the term. In the attached screenshot, I am expecting it to search in the currently selected tab, “new 2”, but it doesn’t find the term.
      YUNGY Terry RT Alan KilbornA 3 Replies Last reply Reply Quote 0
      • andrecool-68A
        andrecool-68
        • YUNGY
          YUNG @Keith Leng
          @Keith-Leng try check the “Wrap around” checkbox
            Terry R @Keith Leng
            @Keith-Leng said in Problem with basic search:
            I see the “in selection” button is ticked. Whilst it looks like the text in the background is selected, is it? If wanting to search an entire document untick the “in selection” button, just in case you do have only a portion selected which does NOT contain the term you are looking for.
            Keith LengK 1 Reply Last reply Reply Quote 3
              Alan Kilborn @Keith Leng
              @Keith-Leng
              So for your case it appears that you are pressing the Find Next button when this search fails? Is that correct?
              If so, you should note that when you have a selection active (like we can see in the righthand part of your screenshot, that a downward search (like you’ve set) will start looking at and beyond the highest position of the selection in the direction of the end of the file. (Interestingly, a backward search – with Backward direction ticked – behaves differently!)
              That’s why you don’t find helping in this example.
              The fact that In selection is ticked has no bearing on this search. If you’ll notice the group box around In selection and Count means that In Selection only applies to Count. So, for Find Next or Find All in Current Document…it is meaningless to have In selection ticked.
              • Keith LengK
                Keith Leng @Terry R
                @Terry-R said in Problem with basic search:
                @Alan-Kilborn said in Problem with basic search:
                @Keith-Leng
                Thanks for the replies. That was the problem. Sorry for my late reply. I didn’t get a notification.
