    multi-part keywords folding doesn't work in other languages
    4 Posts 2 Posters 483 Views
    • Pillow DarkP
      Pillow Dark
      As you can see in this example open and close keywords cannot be found if they are written in other language and in quotation marks
      8626a46e-733b-42ce-8044-89d35943cb28-image.png 74b490d4-427d-4d60-8544-d6a3bd58a0b4-image.png
      Without quotation marks works just fine
      ca539cfe-ccfb-41ef-b827-76901f69dba6-image.png e4ec4e7b-f852-443f-8320-100f873b7ed3-image.png
      And in english too
      ca28b1eb-b7da-4691-9575-e3fc03fa2d75-image.png fe0335d8-b0b0-4bcc-8cf1-3f34251cc1ce-image.png
      Maybe it’s encoding problem but i’m not shure
      • Pillow DarkP
        Pillow Dark
        I’m curious if this was intended or not.
        P.S. sorry for bad English.
          PeterJones @Pillow Dark
          @Pillow-Dark ,
          Unfortunately, the bulk of the User Defined Language (UDL) system was built without encoding in mind, so many of the entries – including the code-folding – don’t properly handle non-ASCII characters.
          There are, unfortunately, many open issues regarding UDL. And at least a half-dozen that I could find that were about UDL’s inadequacies with respect to non-ASCII characters:
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8562
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8399
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/6197
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/6014
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4742
          • https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4688
          Maybe if more people would upvote those, and provide more examples that it’s still not working, the developers would prioritize UDL fixes.
          If you are willing to install a plugin like PythonScript, it’s likely possible to script a solution – I believe that it’s possible to affect code folding from a scripting plugin, similar to the way that @Ekopalypse used regex to enhance any lexer (UDL or builtin), but I’ve never played around with that, and don’t have as much time for PythonScript hacking as I used to. If you give it a go, but get stuck, show us what you have, and we can likely provide advice; or, if it catches someone’s interest, there may be someone here with the time to give it a go and get you to a good head start.
          Sorry I don’t have better news, or a fully-functional workaround, for you.
          • Pillow DarkP
            Pillow Dark
            @PeterJones thanks for the explanation. Maybe I’ll try to fix this myself, but I dont feel confident.
