    A way to detect bracket pairings in a macro?
    3 Posts 2 Posters 363 Views
    • Alt KahA
      Alt Kah
      I would like a way to do the following:
      Position on the first of some sort of structure, like so
      structure header [
        Item 1;
        Item 2 is a Structure
        [ Item 2a;
          Item 2b;
        One last item;
      ]; #end of the structure
      And what I want to be able to do is, select all the lines of text and Ctrl-J them into a single line, so I would end up with this:
      structure header [   Item 1;   Item 2 is a Structure   [ Item 2a;     Item 2b;   ];   One last item; ]; #end of the structure
      Leveraging the logic N++ uses to detect the end bracket when positioned on the beginning. This would get rolled into a macro that handles each line after the joining.
      Any idea how to accomplish this?
        PeterJones @Alt Kah
        @Alt-Kah said in A way to detect bracket pairings in a macro?:
        Fortunately, there are recordable menu commands that do the various steps you want.
        1. Move the cursor to the [ or ] for the brace pair you are interested in
        2. Macro > Start Recording
        3. Search > Select All Between Matching Braces (default shortcut: Ctrl+Alt+B)
        4. Edit > Line Operations > Join Lines (default shortcut: Ctrl+J)
        5. Macro > Stop Recording
        6. Macro > Save Current Recorded Macro to Join Matching Braces or whatever you want to call it, and assign a keyboard shortcut to your liking
        Alt KahA 1 Reply Last reply Reply Quote 3
        • Alt KahA
          Alt Kah @PeterJones
          @PeterJones Thanks! I had no idea there was a “Select All Between Matching Braces” but that will do the trick!
