Is it possible to create "hyperlink" to places within a notepad++ document?
In more advanced word processors we have a table of contents. We click on an item and are immediately taken to the page corresponding to it.
Is there a way to do this in Notepad++ while using plain text files? It would require that Notepad++ identity certain sequence of characters as being a link to another line or marker in the file.
Notepad++ is a text editor, not a word processor.
However, if you’re doing things like code, the builtin feature Function List (enable using the View > Function List menu entry) will allow you to see go immediately to function definitions.
Using the same Function List feature, this post shows the config information that goes into
%AppData%\Notepad++\functionList.xml, which allows the Function List to work with Markdown text headers (so you can quickly navigate between sections in your Markdown documentation).If you define a UDL, then define the Function List setting to accompany it, you could get a table-of-contents-like feature for whatever style of text you have (whether it’s code, Markdown, TODO list, or what have you).
See @MAPJe71’s excellent FAQ Desk: Function List Basics in the FAQ section of the forum for more on how to configure new languages/formats to be visible in the Function List. -
See the functionality of the funclist.js script from the repository https://github.com/trdm/jn-npp-scripts.
I was doing the jump function to the desired line. See functions: gotoAnyHtmlTag (), listFunctions ().
https://github.com/trdm/jn-npp-scripts/blob/master/includes/funclist.js -
@Hassan-Iqbal said in Is it possible to create "hyperlink" to places within a notepad++ document?:
Пример текста можете привести?
