    Calling .js script using c# for a Plugin
    3 Posts 2 Posters 589 Views
    • NanyaRurirosN
      NanyaRuriros
      Hi
      I have 2 .js files that works flawlessly and I want to add them in my plugin already coded in c#, used for string modifications.
      Is it possible to call .js script files using a plugin developed using c#?
      Thanks
        PeterJones @NanyaRuriros
        @NanyaRuriros ,
        It wouldn’t surprise me if it could be. The jN Notepad++ Plugin presumably embeds a JS engine, so you might search for that plugin’s source code to look for ideas.
        As far as C# specifics, there are probably lots of hits for “embed JS in C#” in your favorite search engine for generically embedding, and I doubt the plugin version would be different from the general case.
        Maybe others have some insight as well.
        • NanyaRurirosN
          NanyaRuriros
          @PeterJones said in Calling .js script using c# for a Plugin:
          embed JS in C#
          Thank you!
          I will give it a look :)
