    convert lower to upper and upper to lower aftert colon
    12 Posts 3 Posters 2.9k Views
      FYI:
      The official docs have a section on substitution regex, but the conditional replacements were not explained: https://npp-user-manual.org/docs/searching/#substitutions
      The most recent update to the documentation github has more details on that; it will be in the next release to the doc website (whenever that occurs): https://github.com/notepad-plus-plus/npp-usermanual/blob/852b4ac8a2e667be027d3f7db0a04cfeb2d71eca/content/docs/searching.md#substitution-conditionals
      • real_1bxR
        real_1bx @PeterJones
        @PeterJones said in convert lower to upper and upper to lower aftert colon:
        If I am understanding the logic, you want colon-lowercase to become colon-uppercase, and colon-uppercase to become colon-lowercase, and everything after that to be made lowercase, right? If so, then I think this will work for you:
        Thank you very much, i really do appropriate taking time to help me out.
        the logic is i want colon-lowercase to become colon-uppercase, and colon-uppercase to become colon-lowercase but everything after that stay the same i don’t want change it.
          Hello @real_1bx and All,
          You need to distinguish an uppercase letter from a lowercase letter !
          So, I think that the following regex S/R should work !
          SEARCH (?-is):(([A-Z])|[a-z])(.+)
          REPLACE :(?2\l:\u)\1\L\3
          For instance, the text :
          john:abC232
          smith:SnLf1999
          is changed into :
          john:Abc232
          smith:snlf1999
          Notes :
          • First, the in-line modifiers (?-is) means that :
            • The search will be carried on, in a non-insensitive way ( -i )
            • Any regex dot symbol matches a single standard character only ( and not line-break chars )
          • Groups involved in the search regex are :
            • Group 1 = ([A-Z])|[a-z], so the first letter after the : char, which may be, either a lower-case or an upper-case letter
            • Group 2 = [A-Z], so the first upper-case letter after the :
            • Group 3 = .+, so all the remaining characters of current line, after the : and a first letter
          • In the replacement regex :
            • : rewrites the colon, first
            • Then, the (?2\l:\u) syntax is a conditional structure which forces the next character to be written :
              • In lower case if group 2 exists, that is to say if an upper case letter has matched
              • In upper case if group 2 does not exist => a lower case letter has matched
            • \1 is the first letter whose case has been modified
            • Finally, \L\3 rewrites all the remaining characters, of current line, in lower-case
          • Note that I do not use the look-behind structure (?<=:) which enable us to use the step by step replacement with repeated hits on the Replace button
          @peterjones said :
          I am surprised @guy038 hadn’t chimed in already, since he was around a few minutes ago.
          Well, I was chatting for a moment with my son who’s going back to Lyon ;-)
            PeterJones @real_1bx
            @real_1bx said in convert lower to upper and upper to lower aftert colon:
            Ahh, your \L confused me to thinking you wanted the rest lowercase.
            Just get rid of the third group in find and replace should do it:
            FIND = (?-is)(?<=:)(?:([a-z])|([A-Z]))
            REPLACE = (?1\u$1)(?2\l$2)
            MODE = regular expression
              Hi, @real_1bx, @peterjones and All,
              So, I did the same mistake as Peter !
              Thus, my regex S/R should be modified as :
              SEARCH (?-i):(([A-Z])|[a-z])
                Last news : we don’t even need an outer group to capture the letter ! So, why not this attempt :
                SEARCH (?-i)(:[A-Z])|:[a-z]
                REPLACE (?1\L:\U)$0
                So the following text :
                john:abC232
                smith:SnLf1999
                becomes :
                john:AbC232
                smith:snLf1999
                BR,
                real_1bxR 1 Reply Last reply Reply Quote 2
                • real_1bxR
                  real_1bx @guy038
                  @guy038
                  Thank you very much , that’s saved me a LOT of time.
                    Hello @real_1bx,
                    I hope that you noticed why I use, this time, the (?1\L:\U)$0 syntax ( and not (?1\l:\u)$0 ), in replacement ?
                    Just because the string to convert in upper / lower case ( $0 ) is two chars long ( a colon : + a letter ) !
                    real_1bxR 1 Reply Last reply Reply Quote 1
                    • real_1bxR
                      real_1bx @guy038
                      @guy038 is it possible to delete whole line if there is number after the :
                      i mean the first character after colon not the whole word.
                      like
                      abc:fkls
                      john:13kkmsd
                      smith:kmskl
                      **to be**
                      abc:fkls
                      smith:kmskl
                        Hi, @real_1bx, and All,
                        This time, due to the simultaneous search of an entire line, with its line-break, when a digit follows the colon char, we need, again, two groups, leading up to that regex S/R :
                        SEARCH (?-is)^.+:\d.+\R|((:[A-Z])|:[a-z])
                        REPLACE ?1(?2\L:\U)\1
                        For instance, the input text, below :
                        john:abC232
                        john:13kkmsd
                        smith:SnLf1999
                        would be modified as :
                        john:AbC232
                        smith:snLf1999
                        Best regards,
