    I need help to remove a string
    3 Posts 2 Posters 363 Views
    • SerraCaboS
      SerraCabo
      Hi.
      I have a file containing expressions like:
      (tstamp 0079956c-31f8-44a4-92be-90a7cd4470f3)
      That I need to delete from ( to ).
      Say, I want to replace:
      (tstamp
      until
      by
      “” (nothing)
      (tstamp is, of course the ‘thing’ to look after.
      Could I have some help, please?
      Thanks
      SC
        FIND = \(.*?\)
        REPLACE = empty (nothing)
          On re-reading, I saw a fine point I may have missed: if you only want to delete parenthesized items when it starts with (tstamp, then slight change:
          • FIND = \(tstamp.*?\)
          The rest remains the same.
          With this,
          (blah keep this) (tstamp blah blah) (blah keep this)
          will become
          (blah keep this)  (blah keep this)
          If you have more requirements (the paren must start at the beginning of the line and/or end at the end of the line, or other such modifications), those refined requirements can be met. However, you will need to be more explicit.
          Do you want regex search/replace help? Then please be patient and polite, show some effort, and be willing to learn; answer questions and requests for clarification that are made of you. All example text should be marked as plain text using the </> toolbar button or manual Markdown syntax. Screenshots can be pasted from the clipbpard to your post using Ctrl+V to show graphical items, but any text should be included as literal text in your post so we can easily copy/paste your data. Show the data you have and the text you want to get from that data; include examples of things that should match and be transformed, and things that don’t match and should be left alone; show edge cases and make sure you examples are as varied as your real data. Show the regex you already tried, and why you thought it should work; tell us what’s wrong with what you do get… Read the official NPP Searching / Regex docs and the forum’s Regular Expression FAQ. If you follow these guidelines, you’re much more likely to get helpful replies that solve your problem in the shortest number of tries.
