    Replace specific number and letter
    3 Posts 2 Posters 254 Views
    • Alexandros XatzidimitriouA
      Hello
      ‘Blue1’: ‘0010001000100011’,
      ‘Orange1’: ‘1000100010001000’
      I want to replace number 1 with letter a but I don’t want to change Blue1 and Orange1 text.
      If I use
      Find: \d(‘1)
      Replace: a
      the first number ‘1 and the last number 1’ doesn’t change because there is this symbol (’)… Any solution…? Thanks
        Hello @alexandros-xatzidimitriou, and All,
        Do you mean this kind of replacement ? :
        • Initial text :
        'Blue1': '0010001000100011',
        'Orange1': '1000100010001000'
        • SEARCH 1(?!':)
        • REPLACE a
        • Final text :
        'Blue1': '00a000a000a000aa',
        'Orange1': 'a000a000a000a000'
        Notes :
        • The search regex looks for a 1 digit, ONLY IF NOT  followed with the string ': and replaces it with the lowercase letter a
        • The (?!.......) syntax is a negative look-ahead structure
          Thanks a lot guy038! This is exactly what I was looking for!!!
