    What is the cross-hatching for? (Style Configurator)
    24 Posts 5 Posters 8.9k Views
      Hello, @peterjones, and All
      I just redid the test of my previous post, with :
      • A new fresh dezipped 32 bits portable version of N++ v7.8.5 in a folder, without any additional plugin other than default ones
      • The new dezipped 32 bits portable version of N++ v7.8.6 in an other folder, that I haven’t downloaded, yet
      And I confirm the previous behaviour, with the two colors available, both for v7.8.5 and v7.8.6
      Mauy be, once more, it could be only related to my Win XP configuration ?
      BTW, to get the initial colors and default behaviour of the Style Configurator, simply, stop and restart Notepad++
        I can confirm the behavior.
        But like @PeterJones, I see that only with a fresh version,
        not with my regular version.
        With a fresh version I see the following:
        disabled 	Tag
        		Global override
        		Default Style
        		Indent guideline style
        		Brace highlight style
        		Bad brace colour
        fg 		Current line background colour
        fg 		Selected text colour
        bg 		Caret colour
        bg 		Edge colour
        		Line number margin
        		Fold
        bg 		Fold active
        		Fold margin
        bg 		White space symbol
        fg 		Smart HighLighting
        fg 		Find Mark Style
        fg 		Mark Style 1
        fg 		Mark Style 2
        fg 		Mark Style 3
        fg 		Mark Style 4
        fg 		Mark Style 5
        fg 		Incremental highlight all
        fg 		Tags match highlighting
        fg 		Tags attribute
        bg 		Active tab focused indicator
        bg 		Active tab unfocused indicator
        bg 		Active tab text
        		Inactive tabs
        bg 		URL hovered
        Now, if I change to Bespin theme and back
        all but “Mark Style 2” are enabled.
        But if I do the same test with Choco theme,
        then all of them, including Mark Style 2, will be enabled.
        I haven’t tested with other themes.
          Alan Kilborn @Ekopalypse
          @Ekopalypse said in What is the cross-hatching for? (Style Configurator):
          Can you clarify what this means?
          Same actual version numbers of Notepad++, just a freshly extracted one versus the one you use day-by-day (where maybe you’ve upgraded configuration files manually bit by bit)?
            Ekopalypse @Alan Kilborn
            fresh version = portable, downloaded from npp without any modifications and additional plugins
            regular version = my portable version - highly customized and with additional plugins
            Test was done with npp 7.8.6 (fresh) and 7.8.5 (regular).
